Five volt (wideband) gauge?
Old Jul 13, 2004 | 01:02 PM
Top Ramen's Avatar
Default Five volt (wideband) gauge?
I just put an AEM with the dual widebands into a friend's supercharged NSX and we are having a hard time finding a good way to display the A/F ratios. Anyone know of a gauge that will read a five volt signal? All I can find is the crappy 1 volt systems.
Thanks.
Old Jul 13, 2004 | 01:36 PM
Top Ramen's Avatar
Default Re: Five volt (wideband) gauge? (Top Ramen)
Wierd timing - after a week of looking, I get the answer from Nordskog five min. after I post on here. They make a gauge that will read five volt A/F sensors. Part number M9021.
Old Jul 13, 2004 | 05:41 PM
Natural Aspirations's Avatar
Default Re: Five volt (Top Ramen)
Where can I find this A/F gauge? P/N M9021? I searched but was unable to locate any vendors with this model.
Old Jul 13, 2004 | 09:04 PM
Top Ramen's Avatar
Default Re: Five volt (crixzc)
You can order it directly from Nordskog (http://www.nordskogperformance.net/). They do not have it listed on their site yet. I believe it is the same as the M9200, except calibrated for a five volt range.
Old Jul 13, 2004 | 09:46 PM
Sack Master's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crixzc &raquo;</TD></TR><TR><TD CLASS="quote">Where can I find this A/F gauge? P/N M9021? I searched but was unable to locate any vendors with this model. </TD></TR></TABLE>
Call summit racing. We carry nordskog and can probably get this item for you in a fairly timely manner. That would be P/N NRD-M9201 and if its a new item we will probably have to add it into our system.
Old Jul 13, 2004 | 10:18 PM
JerseySiPOS's Avatar
Default Re: Five volt (Sack Master)
not to steal your thread, but basically you got an aem wideband and you just want to view your a/f ratios??
i can get the techedge wideband do it yourself kit with display or an aem wideband without the display but would need a laptop.
can you really get a digital a/f ratio display for the aem wideband other than getting the aem display which is like $500??
Old Jul 13, 2004 | 10:52 PM
Top Ramen's Avatar
Default Re: Five volt (JerseySiPOS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JerseySiPOS &raquo;</TD></TR><TR><TD CLASS="quote">can you really get a digital a/f ratio display for the aem wideband other than getting the aem display which is like $500??</TD></TR></TABLE>
They (AEM) sell a guage version of the single channel sensor, but not with the dual channel. I hunted down this gauge as a way to have a display with the dual band system. Keep in mind that it is just a guage and not a controller. But, it should work with any five volt wideband/controller set-up.
redboost10
Welding / Fabrication
Aug 29, 2006 06:30 AM
donkiman
Dec 9, 2004 01:23 PM
RCautoworks
Nov 22, 2004 07:30 AM
