d16y8 and vtec controller in 88 si (what wires)
hey i just installed my vtec controller (using the ha-1 diagram) and i was wondering what wires from the vtec controller do i hook up to on the pressure switch. the vtec switch one is simple but the oil pressure switch has 2 wires i think they are green and black and right now i have the wire for the pressure to the red one and i grounded the green one. but i got no vtec everything else works on it like the air pressure and the rpm's and so on.
so if anyone can help me out id appreciate it.
there should be a wire from the vtec controller that goes straight to the ecu pin for vtec pressure. then you wont need to wire the vtec pressure switch on the motor.
