P54 A/C BRACKET QUESTION...dont flame, allready searched...
Old Jul 13, 2004 | 12:07 PM
99lspwr's Avatar
Default P54 A/C BRACKET QUESTION...dont flame, allready searched...
Of course we all know that this is the bracket to use with a b-series engine swap, and a d-series compressor..However, I cant seem to find out if you can still use the d-series pulley, pulley brkt., and bolts....Anyone know, or do I have to get all that b/s too????Thanks
Old Jul 13, 2004 | 12:31 PM
taqman15's Avatar
Default Re: P54 A/C BRACKET QUESTION...dont flame, allready searched... (99lspwr)
yes you can reuse your stock civic pulley, bracket and bolts
Old Jul 13, 2004 | 12:37 PM
99lspwr's Avatar
Default Re: P54 A/C BRACKET QUESTION...dont flame, allready searched... (taqman15)
Thanks alot man, I appriciate the help..
Old Jul 13, 2004 | 01:30 PM
cbaracing's Avatar
the bolts you can reuse and maybe even the pulley itself. you need the b series pulley bracket though. it pivots on the bracket. d series one wont work cause it slides. you should be able to tell all this when you put both ac brackets beside each other.
Old Jul 13, 2004 | 01:56 PM
99lspwr's Avatar
Default Re: P54 A/C BRACKET QUESTION...dont flame, allready searched... (cbaracing)
Thanks for the info guys, but which is it???One person tells me I can re-use all the d-series parts, and another says I need a different pulley bracket...Dont mean to sound all pissy, I just want to make sure I have all the correct parts.... thanks
Old Jul 14, 2004 | 06:37 AM
cbaracing's Avatar
if you get the p54 bracket and compare it with the d series bracket you will see the difference. the bolts will work but the pulley brackets are totally different. the d series slides up and down while the p54 pivots. if you can look at an integra with ac it has the same setup.
Old Jul 14, 2004 | 08:17 AM
eg92b16a2's Avatar
you can also use a crv ac bracket too. they are much cheaper..
Old Jul 14, 2004 | 10:16 AM
99lspwr's Avatar
Default Re: P54 A/C BRACKET QUESTION...dont flame, allready searched... (eg92b16a2)
Keep the info coming, I appriciate it very much.....
CBARACING....Do u think I can reuse the d-series pulley, or will I have to get the one that goes with the p54 bracket??????thanks
Old Jul 14, 2004 | 10:22 AM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99lspwr &raquo;</TD></TR><TR><TD CLASS="quote">Keep the info coming, I appriciate it very much.....
CBARACING....Do u think I can reuse the d-series pulley, or will I have to get the one that goes with the p54 bracket??????thanks</TD></TR></TABLE>
There is no more info to keep comming. You can reuse the pulley if you want, thats fine.. You WILL need the bracket for the P54 in order to adap the idler pulley to it and you should also get the tensioner bolt, tensioner nut and the idler pulley bolt for the B series as well. Thats all there is to it. You cannot just use the entire setup from the D series and make it work. There is not enough items there. cool?
Old Jul 14, 2004 | 01:50 PM
99lspwr's Avatar
Default Re: P54 A/C BRACKET QUESTION...dont flame, allready searched... (Hybrid93Eg)
Just wanted to make sure I get all the right parts, thats all...
Old Jul 14, 2004 | 01:54 PM
cbaracing's Avatar
There is no more info to keep comming. You can reuse the pulley if you want, thats fine.. You WILL need the bracket for the P54 in order to adap the idler pulley to it and you should also get the tensioner bolt, tensioner nut and the idler pulley bolt for the B series as well. Thats all there is to it. You cannot just use the entire setup from the D series and make it work. There is not enough items there. cool?[/QUOTE]
this is what i was trying to say. just didnt come out right. you get the p54 bracket, use your a/c compressor, and get the b series tensioner bolt, nut, and idler pulley.
Old Jul 15, 2004 | 02:18 AM
92b16vx's Avatar
Glad I found this, I am doing the same thing and had the same questions, I am using a P30 bracket, and the compressor doesn't line up, and the tensioner/pulley is completely different.
Old Feb 25, 2005 | 03:35 PM
HKSone's Avatar
Default Re: (92b16vx)
sorry to bring this topic back up, but which a/c belt do I use, from the civic or which? and will i be needing the b- series idler pully or the idler pully bolt only? is the idler pulley from the civic reuseable yes or no? i'm trying to order all the parts together so i need the complete parts list.. thanks
Old Feb 25, 2005 | 03:44 PM
HKSone's Avatar
Default Re: (HKSone)
nvm i found the info thanks
joelj320
Mar 26, 2015 09:03 AM
lmike6453
Apr 1, 2008 05:41 AM
kawaii05
Jun 3, 2006 07:35 AM
marc-111
Aug 22, 2005 08:07 AM
