Let's play "GUESS MY TURBOOOOOOOOOOOO"
Old Jul 13, 2004 | 11:46 AM
Nerologic's Avatar
Default Let's play "GUESS MY TURBOOOOOOOOOOOO"
Il have pics up in like a min or two im still hosting them with image station....i was told its off a mistu but who knows......
Old Jul 13, 2004 | 11:57 AM
Nerologic's Avatar
Default Re: Let's play "GUESS MY TURBOOOOOOOOOOOO" (Nerologic)
here is the fisrt picture, to the right is a t25, to the left is a??
here is the in let it says "AIReasearch" and has a straight inlet unlike the t25
last picture is the exaust housing side of the turbo it says garret
so what turbo do i have?? i can take more pictures if needed TIA
Old Jul 13, 2004 | 12:04 PM
Squirtin EGsr
Guest
Posts: n/a
I am pretty sure that the AIResearch turbos off of a Saab were straight t3s, correct me if i am wrong.
Old Jul 13, 2004 | 12:19 PM
tgreaves's Avatar
Default Re: Let's play "GUESS MY TURBOOOOOOOOOOOO" (RiceRocket12s)
The exhaust housing flange is a T3 flange..
Old Jul 13, 2004 | 12:25 PM
Nerologic's Avatar
Default Re: Let's play "GUESS MY TURBOOOOOOOOOOOO" (tgreaves)
hmmm so i know its a T3....how would i knwo what teh wastegate is set at?? also it has a compressor size number on it let me get the number....
Old Jul 13, 2004 | 12:29 PM
Nerologic's Avatar
alright it has a AR .48, so i know that applies to one side of the turbo, it has a slight crack on top of the turbo housing, can those usually be welded??? il have a pic up in a few....
Old Jul 13, 2004 | 12:42 PM
Nerologic's Avatar
Default Re: (Nerologic)
heres the crack
fixable yay or nay?? and wastgate is set at?? also the turbo volvo turbos i can use for parts this turbo is missing right?
Thanks alot u guys
Old Jul 13, 2004 | 12:50 PM
tgreaves's Avatar
Outch.. I would have that welded.. Dont use some ghetto fix on the exhaust housing..
Easy test for the wastegate.. Go out and get a pressure regulator from home depot(about $20 or so).. Hook up and air hose to one side of it and the other side goes to your wastegate through a hose.. Put an accurate boost gauge on the regulator so you can see what the pressure is.. Then turn the regulator and feel the wastegate.. When its about 45% to 55% opened look at the gauge and thats an estimated guess of your boost.. I did this and it worked great..
Old Jul 13, 2004 | 12:55 PM
USDM 4G VTEC's Avatar
Default Re: (tgreaves)
that is a T3 like they said
more than likely a straight t3
the wastegate more likely is like 7......judgin by what the stock specs are no manufacturers
that housing is foked
u need to bake that thing to 450 degrees and keep it there for 10 minutes
then weld it, and keep it hot for at least 6 hrs afterwards and reduccing at least 100 degrees every hour.. that will make sure the weld stays there and wont brake no more
Old Jul 13, 2004 | 01:06 PM
Nerologic's Avatar
thanks guys for the info , one last thing should i rebuild that t25 tahts in the picture (new seals) or should i make a adapter plate for the T3 and get it welded??? its going on z6 FYI
Old Jul 13, 2004 | 01:10 PM
tgreaves's Avatar
I would use the T3..
Old Jul 13, 2004 | 02:23 PM
ion_four's Avatar
I have a t3 (.42/.48) and I think I would go with the t25, if I had to do it again. I autocross my car and could use a bit more response, but if you're planning on doing more drag-type racing, then I'd go with the t3, I suppose.
Old Jul 13, 2004 | 02:35 PM
JalopySiR's Avatar
https://honda-tech.com/zerothread?id=376502
Old Jul 13, 2004 | 03:02 PM
Nerologic's Avatar
im going to go with the T3 then, all i have to do is make an adapter plate for my Vx manild and weld the top of the manifold and im set, im more into 1/4 deal i dont need it to be responsive so i think im good to go......thanks for the link Jalopy
Old Jul 14, 2004 | 12:28 AM
Nerologic's Avatar
Thanks everyone for playing the game ....but dont u guys wish you were this dude on jepordy
https://honda-tech.com/zerothread?id=925174
mac_24_seven
Aug 20, 2008 11:31 AM
Pro-lite
Aug 15, 2006 12:38 PM
lazybrown187
Dec 9, 2005 09:11 PM
IntegraGSR(-1)
Nov 24, 2005 09:53 AM
Midwestrider
Feb 23, 2003 11:53 PM
