DPFI question/theory... your 2cents please!
Hey I need to do the MPFI swap, as I have an intake, header, exhaust aem gear, and there going to a waste with only 2 injectors. ANyways i have the pm6 ecu, ITB, 4 diff injects unknown origon so i still need the si dizzy, and relay for inj's? correct?
Well heres a question, instead of the MPFI swap can i just puut in some nice larger cc injectors and maybe upgrade the ecu and call it good? will I get as much of a respnse as i would if i did the whole swap?
thanx for your advice/comment ?
Well heres a question, instead of the MPFI swap can i just puut in some nice larger cc injectors and maybe upgrade the ecu and call it good? will I get as much of a respnse as i would if i did the whole swap?thanx for your advice/comment ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX+MaAN »</TD></TR><TR><TD CLASS="quote">Hey I need to do the MPFI swap, as I have an intake, header, exhaust aem gear, and there going to a waste with only 2 injectors. ANyways i have the pm6 ecu, ITB, 4 diff injects unknown origon so i still need the si dizzy, and relay for inj's? correct?</TD></TR></TABLE>
YES
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">
?</TD></TR></TABLE>
"upgrade the ecu"
There really isn't any support for the ECU.
"will I get as much of a respnse as i would if i did the whole swap?"
No. Having the injectors right up at the intake ports is more efficient.
YES
?</TD></TR></TABLE>"upgrade the ecu"
boogerboy72
Apr 22, 2007 07:10 AM
