Why would I choose Full-Race over a Rev-hard kit?
Old Jul 13, 2004 | 08:58 AM
otto's Avatar
Default Why would I choose Full-Race over a Rev-hard kit?
I am in the process of rebuilding my b16 with forged rods and pistons. (9.0-1) I have been told that if i'm not going to build a custom kit for my crx then I should look at the Full-Race kit. I am wondering why I need to spend an extra $1,000 on a Full-Race? I would go with the Full-Race kit if I could justify the extra cost. Any thoughts? I plain to use the car as a daily driver/weekend racer. For now i'm going to run an FMU until I have more funds for a Hondata. Then I will have it tuned by a local shop. Goal is to have 220-250 WHP.
Old Jul 13, 2004 | 09:04 AM
RobbieG35's Avatar
12 Years Strong
Default Re: Why would I choose Full-Race over a Rev-hard kit? (otto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by otto &raquo;</TD></TR><TR><TD CLASS="quote">I am in the process of rebuilding my b16 with forged rods and pistons. (9.0-1) I have been told that if i'm not going to build a custom kit for my crx then I should look at the Full-Race kit. I am wondering why I need to spend an extra $1,000 on a Full-Race? I would go with the Full-Race kit if I could justify the extra cost. Any thoughts? I plain to use the car as a daily driver/weekend racer. For now i'm going to run an FMU until I have more funds for a Hondata. Then I will have it tuned by a local shop. Goal is to have 220-250 WHP. </TD></TR></TABLE>
If 220-250whp is your goal go with Revhard, Full- Race kit is a huge overkill for that
Old Jul 13, 2004 | 09:43 AM
BoostedsiR's Avatar
Default Re: Why would I choose Full-Race over a Rev-hard kit? (HybridHatch88)
why would you go with a full-race kit ? Hmmm quality, just get the revhard that will fill all your needs.
Old Jul 13, 2004 | 09:46 AM
Overblown-Teg's Avatar
With your goal why are you not running a stock engine? The rev hard is probably more what your looking for.
Old Jul 13, 2004 | 09:50 AM
Finland's Avatar
Revhard. Mine's been great for the past 3 years..
Old Jul 13, 2004 | 10:23 AM
FOrSfEd's Avatar
Default Re: (boost psycho)
IF your gonna run an fmu I would just run the revhard
Old Jul 13, 2004 | 10:30 AM
yellowturbo's Avatar
why not go for more than 250 whp ?? If you have forged pistons and rods ??
IMO you should buy the Full-race to get the best one the first time... but its just my opinion...
After you will get your 250 whp you will need more loll
Old Jul 13, 2004 | 11:30 AM
slowpokesi's Avatar
Default Re: (yellowturbo)
first of all, what car do you have
you will be hard pressed to be able to fit a full race turbo kit into a crx, (based off your avatar)
the advantages of the full race kit would obviously be its custom turbo manifold, tial wastegate, and 3 inch downpipe.
revhard doesnt even come with a complete downpipe, youd have to still get it made so that you can bolt it on, it comes with a turbo smart wastegate, and a cast manifold. but would fit alot better in your car than the full race kit (again if you have a crx)
allablur's Avatar
hmm if done corectly you could probably hit your goal with a greddy lol, either will be fine to hit your goal. however, i wouldnt ever never ever never use an FMU at the vary least injectors and have someone rom tune it and if that is done corectly u can boost to 10 lbs wayyyyy better than an fmu and with your goals i would imagine you needing hondata for a while.....unless you get the itch that the rest of us have for more and more power but by then you should be able to afford hondata
Old Jul 13, 2004 | 12:05 PM
c jackson's Avatar
threes
Default Re: (allablur)
actually the full race kit fits in the crx with ease. its in my car, i drive it every day. in fact, i put the motor and the turbo kit in the car in about 8 hours. its very simple.
Old Jul 13, 2004 | 12:38 PM
slowpokesi's Avatar
Default Re: (c jackson)
you got pics of the manifold vs radiator clearance.
also, are you using the stock xmember?
thanks,
Old Jul 13, 2004 | 12:55 PM
otto's Avatar
I would rom tune the car but I don't know of any shops in my area that will do it. I live near Albany, NY. Does anyone have a suggestion for tuner shops?
Old Jul 13, 2004 | 01:20 PM
TurboJesse
Guest
Posts: n/a
Default Re: (otto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by otto &raquo;</TD></TR><TR><TD CLASS="quote">I would rom tune the car but I don't know of any shops in my area that will do it. I live near Albany, NY. Does anyone have a suggestion for tuner shops?</TD></TR></TABLE>
theres nobody around here shop wise.
I'd be more than happy to help you out though, i have all the equipment to get you setup.
Old Jul 13, 2004 | 01:28 PM
G
sh!t happens.
Default Re: (Mpir3)
both kits are really good. i had a rev hard kit on my stock b17a motor and i loved it. im doing a build now and upgrading on parts. im either going to peice a kit together or buy a full race kit.
Old Jul 13, 2004 | 02:04 PM
c jackson's Avatar
threes
Default Re: (slowpokesi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowpokesi &raquo;</TD></TR><TR><TD CLASS="quote">you got pics of the manifold vs radiator clearance.
thanks,</TD></TR></TABLE>
ill post some pictures later, but you have to run a half size rad and if you run a stock crossmemeber you have to cut it up. i have a full-race xmember and it works fine with that.
Old Jul 13, 2004 | 05:30 PM
Turbocivic94's Avatar
Rev Hard would work fine for you
Old Jul 13, 2004 | 06:20 PM
quik sol's Avatar
No other turbo KIT is in the same league with Full-Race, they put ALOT...lemme repeat....ALOT of R&D into there products and when purchasing them you know ya got the best.
I mean comparing rev hard and full-race is like comparing Eagle and Pauter
Old Jul 13, 2004 | 07:08 PM
TurboJesse
Guest
Posts: n/a
Default Re: (quik sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik sol &raquo;</TD></TR><TR><TD CLASS="quote">
I mean comparing rev hard and full-race is like comparing Eagle and Pauter</TD></TR></TABLE>
um people have both gone just as fast with each, lasted just as long, etc...
Full Race is def. The nicest kit out. But what advantages does it offer for a 250whp car? Its not like revhard is ****. I rememember a few years ago Revhard was top of the line. A revhard kit will support just as much HP as the stage 1 FR kits.
Old Jul 14, 2004 | 10:52 AM
Default Re: (Mpir3)
I dont think u will be any faster if u had full race kit. From what I know Jason still uses log style manifold and he's running 9's. I dont think its the manifold that makes that big of difference. Last year Brian had a pos manifold(his own words) and he was running 10's. So I dont think its worth spending the money on full Race manifold unless u r looking for bling
Old Jul 14, 2004 | 11:08 AM
c jackson's Avatar
threes
Default Re: (Turbocivic94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 &raquo;</TD></TR><TR><TD CLASS="quote">I dont think u will be any faster if u had full race kit. From what I know Jason still uses log style manifold and he's running 9's. I dont think its the manifold that makes that big of difference. Last year Brian had a pos manifold(his own words) and he was running 10's. So I dont think its worth spending the money on full Race manifold unless u r looking for bling
i think you need to check out this thread:
https://honda-tech.com/zerothread?id=925312
Old Jul 14, 2004 | 11:10 AM
turbo*s2k's Avatar
Both are nice kits! You can't go wrong with either or...
Old Jul 14, 2004 | 01:07 PM
Yup just saw that. I still think for low hp I cant justify spending that much for manifold
Old Jul 14, 2004 | 04:43 PM
quik sol's Avatar
still not the same quality though...just get the rev hard and save the good kits for us
Old Jul 14, 2004 | 07:50 PM
fullracegsr's Avatar
enough said....
Old Jul 14, 2004 | 09:17 PM
B18C1CYA's Avatar
for your power goals the revhard will do, but if you want more i would go with full-race they have the turbo kits that make the most power from what i have seen, but you will be happy with which ever one you get, just make shure you run a good ems system
