Alternator Replacement
Old Jul 13, 2004 | 04:31 AM
elflacoloco's Avatar
Default Alternator Replacement
Can anyone tell me what alternator is compatible or will work on a JDM B16A1A OBD1 PR 3 ECU engine and what cars did this engine come on originally. I need to want to replace water pump, hoses, timing belt, gaskets, distributor, plugs, wires, rotor, etc. Also, can anyone tell me what would be the best exhaust system for this set up. What size exhaust system should i be running with this stock 170Hp motor.
Thanks,
flaco loco
P.S. I am just a good Dad trying to help out and support my son's interests.
Old Jul 13, 2004 | 07:03 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: Alternator Replacement (elflacoloco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elflacoloco &raquo;</TD></TR><TR><TD CLASS="quote">Can anyone tell me what alternator is compatible or will work on a JDM B16A1A OBD1 PR 3 ECU engine and what cars did this engine come on originally. I need to want to replace water pump, hoses, timing belt, gaskets, distributor, plugs, wires, rotor, etc. Also, can anyone tell me what would be the best exhaust system for this set up. What size exhaust system should i be running with this stock 170Hp motor.</TD></TR></TABLE>
Not sure about the alternator, I'm sure you could go to a local parts store and get a crossreference to different alternators. 2.25" for a stock B series is plenty, larger if you plan on raising the compression or going turbo. Avoid Autozone or equivalent water pumps.. They are teh suck, I'd go OEM Honda. An NGK plug with a heat range of 6 should suffice.
Old Jul 13, 2004 | 07:04 AM
crx2fast's Avatar
so you have a pr3 ECU, and your obd1? i think your obd0 and you have the 160 hp b16a1
i run a 2 1/4 inch exhaust, its great. i wouldnt plain on goin any bigger unless your gona be slapin on a tubo soon
Old Jul 13, 2004 | 07:26 AM
crx_88_si's Avatar
Default Re: Alternator Replacement (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">
Not sure about the alternator, I'm sure you could go to a local parts store and get a crossreference to different alternators. 2.25" for a stock B series is plenty, larger if you plan on raising the compression or going turbo. Avoid Autozone or equivalent water pumps.. They are teh suck, I'd go OEM Honda. An NGK plug with a heat range of 6 should suffice.</TD></TR></TABLE>
I completely agree with this! Honda Parts only, maybe a little more expensive but WORTH it.
phoenix_iii
11
Mar 25, 2009 01:13 PM
Weak!EG
Feb 17, 2007 09:28 PM
progress
Sep 17, 2005 02:44 AM
DieMaster
12
Sep 14, 2004 05:54 PM
253EK
May 11, 2004 11:52 PM
