Where can I get the 3 bolt flange, like the ones on exhausts?
SMSP. JC Whitney, any large speed shop, many header manufacturers, Summit...... Muffler shops. On and on........
Some can be real thin steel so take a good look at them if you can. There are always ways to make things cheaply.
What's your project?
John
John
Yes, I sell them. Just make sure the flange is large enough so that the tubing ID can be increased in order to be the same ID or larger than what you are bolting it to. i.e. B pipe to cat. Cats are measured by their ID so a 2-1/4" cat has a larger outlet than a 2-1/4" b pipe inlet opening.
SMSP I have a RSR exhaust and the b-pipe is 60mm. I need to shorten the b-pipe and I need another 3 bolt flange. Would I need a 2.5" flange? How much is it?
