Eibach Coilover spring locations !!Santa's little helpers wanted!!
Old Jul 12, 2004 | 07:31 PM
Emshhh's Avatar
Default Eibach Coilover spring locations !!Santa's little helpers wanted!!
I did my install with a friend. He said at the time that the spring were al the same size, so it didnt matter which one went where.. but obviously my car is slanted to one side. I jacked it up and counted the coils on each spring, and it looks as if there at two smaller ones on the driver side and two larger ones on the passenger side. THis would make sense that there ARE to differenet size, but my question now is... Which size goes where? I would think the taller ones go in front to support the engine weight right? I just need a reasurance from somebody who knows, cus i gotta switch them up soon.
thnx guys !
btw: i tried searching
Old Jul 12, 2004 | 07:35 PM
Kyles ej1's Avatar
Default Re: Eibach Coilover spring locations !!Santa's little helpers wanted!! (iGfrequency)
si si. i just checked my gc coiloevers i have in my room and the taller ones do go in the front
Old Jul 12, 2004 | 07:36 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Eibach Coilover spring locations !!Santa's little helpers wanted!! (egcoupe)
Taller ones go in the front.
Old Jul 12, 2004 | 07:39 PM
Emshhh's Avatar
Default Re: Eibach Coilover spring locations !!Santa's little helpers wanted!! (shamoo)
thnx guys! one more thing if you could.. are they different Coilover threaded pieces for each size spring? i just thought about that? could you check for me
Old Jul 12, 2004 | 07:51 PM
Emshhh's Avatar
up^
2jza780
Honda CR-V & Element
10
Apr 29, 2020 12:27 PM
Tharshan
Suspension & Brakes
Oct 4, 2012 06:42 AM
fin781
Suspension & Brakes
Apr 3, 2012 11:46 AM
madhatter07
May 13, 2005 12:35 PM
rapid_roy
Jan 20, 2004 12:55 PM
