Gsr with jun cams, valve lash??
Hey my buddy has some jun cams in his integra GSR and was wondering what the valve lash spec's would be??
also what is the torque setting on the bolt that bolts the cam to the cam gear??
thanks a lot...
thanks a lot...
I don't know the answer to this. I have a few suggestions though.
Either call up the company or call the person you bought them from. If that doesn't work then look for a website that would have those figures. Its a simple search.
Finally, post this in the all motor forum, I think you'll have better luck finding guys with Jun cams in there......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">JUN recommends stock valve lash settings for their cams, and according to my manual, the torque for the cam sprocket bolts is 41 ft-lbs.</TD></TR></TABLE>
very questionable about the valve lash..
just call the co. and they will give you the 411
plus the degree the cams should be installed....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.beeks »</TD></TR><TR><TD CLASS="quote">very questionable about the valve lash..
plus the degree the cams should be installed....</TD></TR></TABLE>
Why is it questionable? Stock figures are what JUN recommends (see links below for additional confirmation), and my understanding is that they run them towards the loose end of the factory specs. As for timing, I would just adjust the cam timing along with fuel and ignition tuning on the dyno.
https://honda-tech.com/zerothread?id=562254
https://honda-tech.com/zerothread?id=159818
https://honda-tech.com/zerothread?id=98315
fuel..
Aug 17, 2011 04:50 AM
