Original height of a 89 CRX?
I want to get my car back to the original height does anbody know how high a crx is. It has the adj. GC coilover so i want to raise it up and only lower it .5-1inch. And where i should be measuring it from.?
Well, I am not sure what the stock height is on the CRX. I just happen to also install some GC/Koni Yellows on my car. The best way I found to measure it is to place yourself on an even ground and measure from the top of the wheel to the bottom of the fender. Remember with new springs, they settle so adjust it a lil higher then what you want to lower it.
mesuring from the center of the fender on each wheel stock on 195/60/14 is going to be 25" i know this b/c i mesured it two days ago b/f i installed my h & r springs and kyb gr-2 's
taylorpro
14
Apr 21, 2013 08:05 AM
Thanks guys
