OT: Harness adapter for VAFC?
Old Nov 22, 2001 | 09:08 AM
IGGY's Avatar
Default OT: Harness adapter for VAFC?
Does anyone know where I can get one for a 01 R... I'm getting the VAFC but don't want to cut my wires.
Old Nov 22, 2001 | 09:09 AM
Big Phat R's Avatar
Default Re: OT: Harness adapter for VAFC? (IGGY)
IM Kenji Plennert on this board. He makes them. $250 US I think. they are the same ones you get from King Motorsports to run the Mugen ECU.
Old Nov 22, 2001 | 09:15 AM
IGGY's Avatar
Default Re: OT: Harness adapter for VAFC? (Big Phat R)
So the one that kenji makes is identical to the mugen? will the mugen fit the VAFC?
Old Nov 22, 2001 | 09:18 AM
Big Phat R's Avatar
As far as I know, Kenji makes it for King. There is no such thing as an adapter harness from Mugen, so to speak. You will have to splice into the harness to use the V-AFC, which eliminates the need to splice into the stock harness (which you don't want to cut for warranty reasons btw). The Mugen ECU is OBD1. The harness converts the 2K+ harness to OBD1 equivalent.
Old Nov 22, 2001 | 09:30 AM
IGGY's Avatar
WHAT IS KENJI'S USERNAME??
Old Nov 22, 2001 | 09:32 AM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
kenji
Old Nov 22, 2001 | 09:46 AM
IGGY's Avatar
Default Re: OT: Harness adapter for VAFC? (Dave-ROR)
Old Nov 22, 2001 | 09:47 AM
Big Phat R's Avatar
LOL
Old Nov 22, 2001 | 09:59 AM
IGGY's Avatar
Old Nov 22, 2001 | 10:10 AM
R134's Avatar
Or you could get a Field harness. They are $50 cheaper. Landspeed racing has them.
Old Nov 22, 2001 | 10:20 AM
aklucsarits's Avatar
New User
Dayum! $250?! I though I paid a lot for my Field VTEC controller harness... And that was only about $150... Try Options Auto Salon. They should be able to get you the Field harness for about $150... The Field harness is good for any VTEC controller or other piggy-back computer.
Here's a gratuitous, bandwidth-intensive pic of the Field Vtec controller harness:
This one, Field part # VT-H6 should fit the 97-98 ITR. But I'm pretty sure that they also sell a model with the '00+ pin-outs too.
Andrew
Old Nov 22, 2001 | 10:21 AM
New User
Default Re: OT: Harness adapter for VAFC? (R134)
Aw crap. You beat me to the post...
Old Nov 23, 2001 | 10:44 AM
IGGY's Avatar
Default Re: OT: Harness adapter for VAFC? (aklucsarits)
I talked to Kenji he sells them for $235 shipped! What is field harness exactly?
Old Nov 23, 2001 | 11:52 AM
arren123's Avatar
Man.. I can't believe how much they can charge for pieces of plastic and wire.
If you had those plastic adapters, wire, and a wiring diagram, i bet you can put one together yourself.
Old Nov 23, 2001 | 12:28 PM
R134's Avatar
Default Re: OT: Harness adapter for VAFC? (arren123)
It would be really easy to make since it's just a jumper harness. You wouldn't even need a wiring diagram. It's just hard finding the connectors. The field is cheaper but you need to cut into the wires. Kenji can probably make a totally plug and play one. It's up to you.
Old Nov 23, 2001 | 12:48 PM
IGGY's Avatar
Well I heard that all that krimping and wiring takes a lot of time to do, and the ones you buy are already tested for problems.... Saves a lot trouble to buy one.
Does Kenji make one that will plug and play? If so that would be best!
Old Nov 23, 2001 | 11:28 PM
SleepyR's Avatar
New User
I don't think the Fields harness would work for OBDII. inlinefour.com had something about it not being compatible
Old Nov 24, 2001 | 11:02 AM
New User
Default Re: OT: Harness adapter for VAFC? (SleepyR)
The Field harness is "plug and play" already. Look at the pics. See all those bullet connectors? That's where you plug in... The RPM, throttle, power, pressure, etc. wires are already color-coded and equiped with nice bullet connectors for you. You don't have to cut anything on the Field harness. You just need to attach bullet connectors to your V-AFC wires to plug 'em in.
I'm not sure what you mean about it not being compatibile with OBD2 cars... It's just a wiring harness. You just need to get the model that has plug connectors and wiring that match your car. The model in that pic (VT-H6) works fine on 97+ OBD2 Preludes and 96-98 OBD2 Integras. You just need to find out if Field makes a model that fits 99+ integra harnesses...
Andrew
Old Nov 24, 2001 | 01:59 PM
nsx-Animal's Avatar
$250 Dollars!! good lord that's a lot of money....
Old Nov 24, 2001 | 02:04 PM
Jason's Avatar
Default Re: OT: Harness adapter for VAFC? (ITR-Animal)
yeah, for 6 bucks worth of wires and overpriced proprietary connectors!
Old Nov 24, 2001 | 03:18 PM
tr4il's Avatar
Default Re: OT: Harness adapter for VAFC? (typer98)
yea if i knew how to do it ide sell it for $20 + shipping
Old Nov 24, 2001 | 04:50 PM
YodaIsGod
Guest
Posts: n/a
Hey Iggy, I know Austin told you I still have mine, and it's ready to go for the V-AFC. $200 and it's yours!
here are some pics of the one that Kenji made for me.
Old Nov 25, 2001 | 11:53 AM
R134's Avatar
It will not be totally plug and play. the bullet connectors are for the field controller. vafc uses some of the same connectors but requires additional ones such as tps sensor but doesn't use the speed sensor. vafc also requires you to tap off the power twice and the ground twice. so you will have to cut into the field harness a little to make it work with vafc.
Old Nov 25, 2001 | 05:27 PM
IGGY's Avatar
Default Re: OT: Harness adapter for VAFC? (YodaIsGod)
Hey Yoda is the foot for sale too in pic 4? How much?
Old Nov 25, 2001 | 06:23 PM
norice's Avatar
Are the connectors proprietary? Surely they could be bought from a Honda/Acura dealership? The plug that the ECU slots into (whether it be ODB1 or ODBII) should be in Honda's parts catalogue?
To make an adapter oneself, all one would need is an OBDI and OBDII connector from the local parts department, a few dollars worth of wire, a pinout diagram (freely available methinks), and some patience.
Am I missing something?
