Mugen head gasket
Old Jul 12, 2004 | 03:51 PM
grenthang's Avatar
Default Mugen head gasket
Is it worth the money to buy the mugen head gasket or the spoon head gasket.
Old Jul 12, 2004 | 06:33 PM
Padawan's Avatar
Darth ModerVader
Default Re: Mugen head gasket (grenthang)
It's a relatively inexpensive way to boost your compression slightly. Whether or not it's "worth it" depends on if you're doing the labor yourself or paying someone else. Also, everyone's opinion of what something is worth is different, so you'll have to decide that for yourself. That being said, I can't think of any less expensive ways to bump the compression the approximate 0.3:1 that both gaskets will provide on a B18C, assuming you aren't paying for labor.
Old Jul 12, 2004 | 07:24 PM
asubennett's Avatar
Default Re: Mugen head gasket (Padawan)
You could also have your head milled for about $30-40 if your going to have head off anyway for the gasket this could be a viable, even more affordable option. Plus you can still use your OEM gasket and trust it's sealing ability.
Old Jul 12, 2004 | 07:33 PM
grenthang's Avatar
Default Re: Mugen head gasket (asubennett)
Yeah i am doing the work my self but i have heard that when u mill a head u cant use some aggressive cams.
Old Jul 12, 2004 | 07:48 PM
asubennett's Avatar
It depends on the pistons and the block. The valve reliefs in your pistons will play a role as will your piston to deck clearence.
Typically .020 of any head that is on any OEM block with OEM pistons will have clearence with cams that don't lift beyond 12mm. This is a very general guideline still always best to clay for clearence.
Old Jul 12, 2004 | 09:30 PM
Tbone's Avatar
Make your own, just remove the rivets that hold the gasket layers together and remove the top layer then lightly copper spray the remaining 2 and install. I have done this many times. I have also owned 4 mugens in my time.
Old Jul 12, 2004 | 09:33 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Mugen head gasket (Tbone)
ya most guys i know just take the rivets out and use 1 or 2 of the 3 layers
Old Jul 12, 2004 | 09:45 PM
krazie1's Avatar
BANNED
Default Re: Mugen head gasket (Hella_JDM)
okay on this subject
if u take out the rivets do u assemble head and block with head gasket like that w/o rivets or do u fab something to install rivets on the gasket again?????
interested to do this
Old Jul 13, 2004 | 01:57 PM
asubennett's Avatar
Default Re: Mugen head gasket (krazie1)
once the rivets are removed leave them off. They are only there to hold the three layers together.
purposebuilt
Oct 1, 2018 09:48 PM
JDMlyfestyle
Mar 25, 2004 01:35 PM
ILOVEGIRLS
Aug 6, 2002 12:46 PM
Rhetoric
Jul 29, 2002 03:30 PM
RTW DC2R
May 24, 2002 06:52 AM
