ITR internals in a 94 LS?????
will the internals of the ITR engine fit in an ls?? Like valve springs, valves cams ETC. without work, just a strait up swap. i think they should but i just want to make sure
um, vtec cams do not fit in a non-vtec head, unless you're building an ls/vtec mongrel motor
[Modified by Benjamin Tang, 11:09 AM 11/22/2001]
If you use the B18C's rods then you will shorten the stroke and lose displacement!
The B18C's stroke is 87.2mm and the B18A/B's stroke is 89mm!
