2000 Accord SE Panic Alarm Problem
Old Jul 12, 2004 | 02:20 PM
nuclearfurnace's Avatar
Default 2000 Accord SE Panic Alarm Problem
I have a 2000 Accord SE and lately when I start the car the panic alarm just sounds. It cannot be shut off. THe panic button, ignition etc have all been attempted but the alarm must time out. Obviously this is unacceptable at 5a when I leave for work etc... Anyone have any ideas what can cause this? It happened a month ago, I made an appointment at the dealer and then it stopped. So they told me nothing was wrong. Now it is happening again. If there is a way I can disable the alarm that would be great too.
Old Jul 17, 2004 | 11:18 AM
EK k kay's Avatar
Default Re: 2000 Accord SE Panic Alarm Problem (nuclearfurnace)
If the ignition won't turn on and the siren is going off then try getting out of the car and inserting the key into the driver side door and turning it. My sisters 97 accord has the same thing and sometimes she either turns the ignition to turn it off or uses the method above. Hope this helps.
Old Jul 17, 2004 | 08:59 PM
accordselux's Avatar
Me Gusta History
have you accidentaly pressed the lock button? I've noticed if you use your remote to lock the car, then start it up, your car thinks you locked the car from outside and someone's stealing you car...
Vazquezball
Jun 29, 2018 02:45 PM
anthonymarriott
Sep 19, 2017 12:26 AM
cruise
Mar 15, 2011 09:40 PM
mila
Jun 6, 2007 04:03 PM
mila
Audio / Security / Video
May 14, 2007 12:38 PM
