A/C in eg with 2000 b16 compressor
what you need is that compressor off the d15 and the ac/tensioner bracket from a 95 del-sol si dohc vtec (b16a2). bolt the old d15 compressor to the new mount, charge it up and you should be ready to chill. you will need a new belt for a 95 del sol to make her spin. g/l
So the d15 compressor bolts directly to the del sol bracket? I have a 00 si ac bracket and it doesn't bolt directly, like 1 bolt fits, the other 3 are off.
if you use the d15 compressor and the b16 mount/tensioner you will be able to get 2 bolts in (both on the right side) and it will line up perfectly. if you dont like the idea of using 2 bolts, then use the delsol ac mount (p54 i think) it will bolt the the b16 block and the d15 compressor perfectly.
lhd dc2
Aug 11, 2005 04:10 PM
