jdm gsr into 95 cx... wiring o2 question...
Old Jul 12, 2004 | 12:40 PM
shorty91's Avatar
Default jdm gsr into 95 cx... wiring o2 question...
i have already searched and cant find anything....
so since i cant use my jdm engine harness, and i cant find any usdm gsr harnesses i have decided to use my cx harness and add all the vtec wires. what do i need to do for my 4 wire o2 sensor? my cx harness is for a one wire o2 sensor.
Old Jul 13, 2004 | 03:23 PM
shorty91's Avatar
Default Re: jdm gsr into 95 cx... wiring o2 question... (shorty91)
ummm ok...
Old Jul 13, 2004 | 03:28 PM
Kendall's Avatar
You'll need to run the wire from the O2 sensor heater to the ECU. I'm not sure if the two black wires would work if grounded out, however I do know that one of them connects to one of the wires coming from the TPS, and that the other terminates where the yellow and black wires from the fuel injectors terminate. Make sure that there is a clean connection between all the wires, and that each one is properly soldered and heat-shrinked. I've seen a lot of cars run like **** from bad O2 sensor connections, most didn't throw any codes.
Old Jul 13, 2004 | 06:03 PM
H2B just chillin's Avatar
NEVER SEEN A SINGLE WIRE O2 SENSOR BEFORE
Old Jul 13, 2004 | 06:57 PM
Andres-eh2's Avatar
I just did this on my car last week. 2 ways. you can either get the wires at the shock tower harness or run the wires behind the ECU. ECU pinout will be given just in case, however i just tapped into them there in the bay
I fit a 93 CX harness on a b18a1 (obd1).
Heres what you do. I hope you have the 4 wire o2 already, it would also help if you had a other side of the o2 plug to retain the adapter. soldering is highly recommended
Step 1:
Solder the White wire on the engine harness to the white wire on the o2.
Pinout: D14
Step 2:
Look for a GRN/WHT Wire on the pass. side harness and tap in there.
Pinout: D22
Step 3:
Look for a ORN/BLK Wire on the pass. side harness and tap in there.
Pinout: A6
Step 4:
With a test light look for a YEL/BLK Wire on the driver side harness. Check for power with the ignition on the on position and ACC. Tap in and solder.
Good Luck and run codes if you get any.
Old Jul 13, 2004 | 07:36 PM
even91civic's Avatar
Default Re: (Andres-eh2)
in the 91 dx can you wire in a 4 wire the same once you convert to a obd1 computer
Old Jul 13, 2004 | 08:37 PM
Andres-eh2's Avatar
i believe the obd1 pinouts will be the same location behind the ECU, dont know if it will be at the shock tower harness
hbyrd8701
Jul 28, 2006 04:58 AM
sLoWrAcEr
12
Apr 4, 2005 02:41 PM
lsvtecracer
Apr 4, 2003 02:44 PM
DevineCRX
Jul 18, 2002 07:31 AM
monsta
Apr 30, 2002 10:25 AM
