Getting aligned today, need assist with what the numbers should be
Old Jul 12, 2004 | 12:18 PM
Ill's Avatar
Ill
Default Getting aligned today, need assist with what the numbers should be
98R, stock sus, and what seems like bad toe (bad rear 'camber' wear). +43 Volk 15x7's with 205/50's.
Will be aligned on a late 2003/2004 manufactured Hunter machine that supposedly now has Type R settings in it (I checked). I have about an hour to and hour and a half before I leave for the appt. Can anyone help me with the numbers that I 'should' be getting the car set to?
If not I'll post the deets on what they did off the spec sheet I will be requesting. They will warranty the alignment and are reputable, so if it's wrong, I can go back and get it fixed free. TIA.
Old Jul 12, 2004 | 12:31 PM
SlapSmak's Avatar
Default Re: Getting aligned today, need assist with what the numbers should be (Ill)
0 toe rear
1/16" toe OUT front
Old Jul 12, 2004 | 12:45 PM
lanceh's Avatar
25 Year Member
Default Re: Getting aligned today, need assist with what the numbers should be (SlapSmak)
i won't go toe out in the front unless you autox/track the car.
Old Jul 12, 2004 | 12:58 PM
Big Phat R's Avatar
Make sure to ask for a 'before' and 'after' printout of alignment specs.
Old Jul 12, 2004 | 02:05 PM
Ill's Avatar
Ill
Default Re: Getting aligned today, need assist with what the numbers should be (Big Phat R)
Hot, thanks! Loving HT as usual.
Old Jul 12, 2004 | 02:20 PM
jond's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlapSmak &raquo;</TD></TR><TR><TD CLASS="quote">0 toe rear
1/16" toe OUT front
When you tell them that, is it usually understood that thats per side, or do you need to tell them 1/16th on each side?
marsvolta
14
Mar 23, 2008 09:13 PM
SWC
Suspension & Brakes
Jun 21, 2006 05:04 AM
speedracer33
23
Jul 26, 2004 10:48 AM
JimmyAtlantis
Jun 2, 2004 08:57 AM
albert butterbikini
Jan 29, 2002 05:48 PM
