Looking to buy a fullbody coilover kit in the near future, need some help deciding
I just had some questions about full coilover kits:
1) I noticed that some sites have the ITR and EF civic listed as the same part number, are they the same (provided u use the 88 crx lca)? by same i mean same length, travel etc??
2) I saw on JHPusa.com that they have the Omnipower coilovers for ef's yet nowhere else has an ef application. Typo? or is it for real?
3 and final q) If you had a choice about which ones to buy what would it be and why? (price range<1000$)
thanks alot for your input
All I can help you with is that I contacted JHPUSA.com a while ago and they said that the EG coilovers will work for an EF, so if you buy them, thats what you are getting. So I then contacted Omni, and they said that would probably work, but it wouldn't be fine tuned like an actual set for our cars would be. Omni also said that they are working on EF full coilovers now and that they should be out soon, so you should probably contact Omniman through Omnipowerusa.com.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MonoDestro »</TD></TR><TR><TD CLASS="quote">All I can help you with is that I contacted JHPUSA.com a while ago and they said that the EG coilovers will work for an EF</TD></TR></TABLE>
Don't they tell you that you would have to change the front shock forks as eg have bigger front forks.
They didn't say anything about that which is why I wouldn't buy them myself. I would wait until the actual product comes out.
ok thanks for clearing that up,
another question i have, is the itr suspension the same (dimensions etc..) as an 88 crx?
Canadian_EF
Nov 26, 2015 10:00 AM
Canadian_EF
Suspension & Brakes
Nov 17, 2015 02:19 PM
YTYPER
Jan 16, 2006 11:03 AM
