having trouble removing a zc tiiming belt cover
Ok, im trying to remove the water pump, but i cant get it completly off since the inner part of the belt cover is in the way. Its around the motor mount, and i cant find a way of getting it off. Is there a bolt or screw or anything that i may be missing? by the way, the car is a DOHC zc crx. Thanks
There should be 1 10mm bolt directly under the motor mount. Its in a 1/4" hole you might have to use your finger to get to it. After that, you still need to drop your crank pulley to get the T-Belt cover off.
Jaydo
Jul 9, 2004 03:51 PM
EFsleeper
Aug 15, 2003 04:05 PM
