heat always on
Old Jul 12, 2004 | 10:59 AM
wetzelman1's Avatar
Default heat always on
i have a 92 accord and the heat won't turn off. The problem started when i turned the heat up and the **** broke. After that the car absolutely blasts heat. In the winter it's kinda nice but in the summer, i can't turn the fans on or anything and obviously the ac doesn't work so it gets hall hot. I think it was also making my head unit over heat as it would get extremely hot if i was using it for over an hour. I've used the fan control **** to tunr the heat control back down but it didn't do anything. How can i fix this?
Old Jul 12, 2004 | 12:28 PM
under advisement's Avatar
Default Re: heat always on (wetzelman1)
Follow the heater hoses to the firewall. You should find a valve that controls how much hot water goes into your heater core. Check to make sure the cable that goes to it is hooked up. Then check to see if you can move the valve. If the cable moves but the valve won't you probably need a new valve. If the valve moves and the cable moves you may just need to reattach or adjust the cable. Occasionally you need a new cable but usually it's just a bad valve or a cable out of adjustment.
navcc
Apr 28, 2013 01:33 PM
91prelude4me
Apr 6, 2010 03:46 PM
jmar97
Dec 13, 2004 10:51 AM
4DRmafia
Jul 11, 2004 02:07 PM
speedbeast
May 9, 2004 01:53 PM
