throttle body gasket
I need a new throttle body gasket. The old one is worn out and falling apart. Will a d16 throttle body gasket fit on a b16 throttle body without any problems in size? Need to know because the store that im buying it from does not specify if it is for a sohc vtec or dohc vtec del sol.
I think the b16 throttle body has a bigger opening, but I dont know if that would affect the gasket. You could always prob cut the gasket to make it fit.
Why not just go to a dealer, the gaskets are cheap, like 5 bucks.
Peter Langly
Jun 18, 2004 03:19 PM
