What transimission fluid did you guys use?
Old Nov 21, 2001 | 11:59 PM
Pure R Racer's Avatar
Default What transimission fluid did you guys use?
Okay, i have 22225 miles on my car. so i figure it's time to change my transmission fluid. What should I use? the redline MTL or MT-90?
Old Nov 22, 2001 | 03:51 AM
RagingAngel's Avatar
Default Re: What transimission fluid did you guys use? (Pure R Racer)
use Honda MTF .......
best **** out there I sincerely believe for the stock R tranny......
I use Redline MTF with Ford Fric. modifier because I have a KAAZ..... starting to wonder if Hondat MTF with Ford Fric. will do the trick instead....
hrmmmm
Old Nov 22, 2001 | 04:34 AM
nsxtcjr's Avatar
New User
Honda MTF. A search will turn up lots of good information in this topic:
https://honda-tech.com/zerothread?id=91239
Old Nov 22, 2001 | 05:23 AM
Dipshit Dan's Avatar
Default Re: What transimission fluid did you guys use? (nsxtcjr)
I'd stay away from Redline on Hondas. It wears the synchros very quickly. I use BG synchroshift, Amsoil, Kaaz or combinations of those depending on what you have done to tha trans.
Old Nov 22, 2001 | 05:51 AM
JohnnyBoy's Avatar
Default Re: What transimission fluid did you guys use? (God)
I've used Redline MTL since the first reccomended change and my syncros are still fine. I have 96000km and have had no problems with the car. I do drive it hard and race it often too. I may try Motul 90PA next though.....
[Modified by JohnnyBoy, 6:52 AM 11/22/2001]
[Modified by JohnnyBoy, 9:29 AM 11/22/2001]
Old Nov 22, 2001 | 05:57 AM
Benjamin Tang's Avatar
Default Re: What transimission fluid did you guys use? (JohnnyBoy)
honda mtf... just adding my vote
Old Nov 22, 2001 | 06:49 AM
Default Re: What transimission fluid did you guys use? (Benjamin Tang)
Really Johnny? I used MTL and it killed my synchros in 40,000 miles. After that replaced synchro and used BG fluid. Zero problems up to 108,000 miles when I sold it.
Old Nov 22, 2001 | 10:09 AM
Dee's Avatar
Dee
I have been using 80w-90 gear oil for fwd trannies since '94 w/o any problems..
Old Nov 22, 2001 | 10:10 AM
Big Phat R's Avatar
Honda MTF
Old Nov 22, 2001 | 11:15 AM
ILOVEGIRLS's Avatar
Default Re: What transimission fluid did you guys use? (Big Phat R)
i got a bad 5th gear syncro..howmuch is it to fix? will honda mtf make a diff?
Old Nov 22, 2001 | 03:03 PM
nsxtcjr's Avatar
New User
Default Re: What transimission fluid did you guys use? (ILOVEGIRLS)
If the synchro is bad, you need to replace it - no fluid is going to fix it for you.
Old Nov 22, 2001 | 04:37 PM
mugenr#1011's Avatar
honda mtf
Old Nov 22, 2001 | 05:59 PM
ILOVEGIRLS's Avatar
shoot..i changed out my fluid today with honda mtf. i noticed that i only poured out about 1 quart out of the tranny..i never meesed around with the fluid before..what would cause it to be so low?
Old Nov 22, 2001 | 06:11 PM
Hooch'n's Avatar
Yeah, Honda MTF is the best. Just my .02$
Old Nov 22, 2001 | 06:50 PM
Kengs's Avatar
Default Re: What transimission fluid did you guys use? (8400-RPM)
I was told HKS FF/Diff is really good; gonna try it soon
Birdley42008
Mar 26, 2010 07:48 PM
sloweredcivic
Sep 21, 2005 08:27 PM
All Motor TypeR 133
Feb 13, 2003 01:00 PM
qwklude82
Jan 4, 2003 11:26 AM
KooK
Jul 29, 2002 03:06 AM
