Check out these rear Lca's....
Old Jul 12, 2004 | 08:00 AM
turbotime's Avatar
Default Check out these rear Lca's....
Well as with all eg's my rear lca's had the strut bolts melded onto them thanks to 200k of rust. ANyway I need to repalce my rear lca's now and i was thinking instead of stock maybe getting either of these:
http://cgi.ebay.com/ebaymotors...33583
They certainly are cheap, or as cheap as I could get OEM ones for. Aside from the flamboyant 'racing' look of them do you think they provide any advantages over stock?
Old Jul 12, 2004 | 08:04 AM
deeksmooth's Avatar
Default Re: Check out these rear Lca's.... (turbotime)
i have them on my car... same length as stock, actuallly same dimensions... they're alright for OEM replacement. but if you're looking to correct camber or anything, these won't do.
Old Jul 12, 2004 | 08:30 AM
turbotime's Avatar
yeah i just need them to replace my oem lca's, if i needed to correct camber i would just buy a camber kit, isnt that seperate from the rear lca?
Old Jul 12, 2004 | 08:44 AM
toolowsol's Avatar
Default Re: (turbotime)
Some aftermarket LCA's are a little shorter, this brings the camber back into spec on a lowered vehical without the use of a camber kit or washers
Old Jul 12, 2004 | 08:45 AM
toolowsol's Avatar
Default Re: (toolowsol)
NOTE: the reason that is an advantous method of correctin camber is because it doesn't push the top of the wheel out any more than it is already, so this can help prevent rubbing problems.
Old Jul 12, 2004 | 09:23 AM
JDMlyfestyle's Avatar
Meagen ive heard bad things about the bushings going out in a week. and the other LCA's $44 just for shipping god thats alot.
Id go with the SRR LCA over any of them
Old Jul 12, 2004 | 09:37 AM
Jon V's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toolowsol &raquo;</TD></TR><TR><TD CLASS="quote">Some aftermarket LCA's are a little shorter, this brings the camber back into spec on a lowered vehical without the use of a camber kit or washers</TD></TR></TABLE>
which one's are these?
Old Jul 12, 2004 | 10:21 AM
underpressure02's Avatar
I heard bad things about megans also. I heard the bushings wear out like a week after installing them.
I would go with srr
Old Jul 12, 2004 | 11:17 AM
North_Texas's Avatar
Default Re: Check out these rear Lca's.... (underpressure02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 &raquo;</TD></TR><TR><TD CLASS="quote">I heard bad things about megans also. I heard the bushings wear out like a week after installing them.
I would go with srr</TD></TR></TABLE>
Couldn't you just upgrade the bushings? Say energy suspension bushings?
Old Jul 12, 2004 | 11:20 AM
igo4bmx's Avatar
Default Re: (Jon V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon V &raquo;</TD></TR><TR><TD CLASS="quote">which one's are these?</TD></TR></TABLE>
SPC makes a set which i currently have on my ride...
they are solid
Old Jul 12, 2004 | 11:26 AM
hayabusa160's Avatar
Default Re: Check out these rear Lca's.... (DixieRedneck)
yea you can do that. reason i got SRR ones caz mines were siezed to ****. i wanted the bling and the hole for the sway bar was a nice feature.
SPC is the only lca that corrects camber by being shorter then stock
the function 7 ones had optional bushings that can be adjusted to correct camber also not sure if they still have that or not
Old Jul 12, 2004 | 12:09 PM
Jon V's Avatar
Default Re: (igo4bmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx &raquo;</TD></TR><TR><TD CLASS="quote">SPC makes a set which i currently have on my ride...
they are solid</TD></TR></TABLE>
any advice on where to get them? any price range?
integra6650's Avatar
is there a weight savings with these lca's
Old Jul 12, 2004 | 12:12 PM
Default Re: Check out these rear Lca's.... (integra6650)
srr ones are 2pounds vs the stock 4pound
Old Jul 12, 2004 | 12:13 PM
EFing_bmxED's Avatar
definitely lighter
Old Jul 12, 2004 | 12:24 PM
igo4bmx's Avatar
Default Re: (Jon V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon V &raquo;</TD></TR><TR><TD CLASS="quote">any advice on where to get them? any price range?</TD></TR></TABLE>
i got mine from ebay...
check our sponsors
Old Jul 13, 2004 | 04:49 AM
well mine are fine for now but when i get to the point were i want to spend alot to lose more weight this is a definantly good idea
swizz977
Suspension & Brakes
Dec 22, 2013 06:27 AM
Racer02gtstang
Suspension & Brakes
Mar 10, 2013 04:10 PM
miguey310
Sep 19, 2011 09:24 AM
EG2Driver
Suspension & Brakes
May 9, 2006 12:17 PM
MrCivic98
Suspension & Brakes
Oct 31, 2005 07:25 AM
