D15b help please...i'm swapping now!
Old Jul 12, 2004 | 07:00 AM
FERIOkid's Avatar
Default D15b help please...i'm swapping now!
New information:
we get it fired up and it idles fine and the timeing is corret but when you go to rev the motor it bogs and sparks shoot from where the distributor hits the block. Then you loosen the distributor and it revs just fine. I'm not sure what the hell the problem is and i could really use some help. I'm about to have the bitch towed to a garage and have somebody get it running right for me.
Modified by slowdx9585 at 11:36 AM 7/13/2004
Old Jul 12, 2004 | 07:07 AM
FERIOkid's Avatar
Default Re: D15b help please...i'm swapping now! (slowdx9585)
come on!!!!
Old Jul 12, 2004 | 07:26 AM
steve_s's Avatar
Did you change the timing belt and if you did are you sure its right?
Old Jul 12, 2004 | 07:29 AM
FERIOkid's Avatar
Default Re: D15b help please...i'm swapping now! (steve_s)
i did not change the timing belt. This motor is supposed to have 35000-45000 km on it. We are trying the old distributor from my other motor and if that doesn't work i will die. I have been up since 12:30 this morning working on this peice and i'm getting a little angry about now
Old Jul 12, 2004 | 07:45 AM
steve_s's Avatar
Im doing the same swap so I know the feeling of frustration. Take a break and relax, go have a smoke if you smoke. Cuz your gonna end up hurting yourself if your frustrated by not using your head.
Old Jul 12, 2004 | 07:46 AM
spyderracing's Avatar
VX timing belt.... i think
Old Jul 12, 2004 | 07:58 AM
steve_s's Avatar
Default Re: D15b help please...i'm swapping now! (spyderracing32)
Yea it is a VX timing belt but if he didnt change it then it still most likely has a vx timing belt. You can check by looking at the number on the belt, it starts with P08 I believe.
Old Jul 12, 2004 | 08:30 AM
Slammd Sol's Avatar
recheck all your wiring and every sensor
Old Jul 12, 2004 | 08:43 AM
snoochtodanooch's Avatar
Default Re: (Slammd Sol)
start doing everything, reset the ecu. check the fuel filter, check the tps, check the egr, everything. to me it sounds like a timing issue, but you never know
Old Jul 12, 2004 | 08:48 AM
FERIOkid's Avatar
Default Re: (snoochtodanooch)
come to find out the distributor that came with the motor was beat and the USDM one works but has to be modded to fit so thats what i'm doing
Old Jul 12, 2004 | 08:58 AM
0ptimus prime's Avatar
Default Re: (slowdx9585)
it's always the simple things... make sure you don't have any sensors switched, and also check your firing order.
Old Jul 12, 2004 | 09:07 AM
H22A EG6's Avatar
Default Re: (0ptimus Prime)
I had the same prob!
the firing order was messed up
i based mine off my teg and my H22 hatch
the DOHC firing order on the dizzy is different than the SOCH
check that out!
Old Jul 12, 2004 | 09:36 AM
steve_s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowdx9585 &raquo;</TD></TR><TR><TD CLASS="quote">come to find out the distributor that came with the motor was beat and the USDM one works but has to be modded to fit so thats what i'm doing </TD></TR></TABLE>
What has to be modified about it?
Old Jul 12, 2004 | 03:09 PM
FERIOkid's Avatar
Default Re: (steve_s)
new info up top
Old Jul 13, 2004 | 07:35 AM
FERIOkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steve_s &raquo;</TD></TR><TR><TD CLASS="quote">
What has to be modified about it?</TD></TR></TABLE>
the d15b7 bracket on the dizzy is different than the d15b bracket
Old Jul 13, 2004 | 08:24 AM
spnbb2
Guest
Posts: n/a
i wuld still change the timing belt on that thing....even though it only has 30k miles on it that engine has most likely been sitting in a warehouse for YEARS
give the engine a proper tune up
Old Jul 13, 2004 | 10:10 AM
FERIOkid's Avatar
Default Re: (SPN BB2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPN BB2 &raquo;</TD></TR><TR><TD CLASS="quote">i wuld still change the timing belt on that thing....even though it only has 30k miles on it that engine has most likely been sitting in a warehouse for YEARS
give the engine a proper tune up</TD></TR></TABLE>
just might have to do that...thanks a lot man
Old Jul 13, 2004 | 10:32 AM
civicminded92's Avatar
the d15b7 bracket on the dizzy is different than the d15b bracket </TD></TR></TABLE>
The proper distributer is one from either the Z6 or Z1. Did you check to see if the wiring of the B7 dizzy is the same as either of the above? If you didn't, I'll bet that's your problem - - the timing will be way off to if the electronic part even works.
Old Jul 13, 2004 | 06:55 PM
FERIOkid's Avatar
this car sucks i'm sendin it to a garage end or story
Old Jul 13, 2004 | 08:45 PM
North_Texas's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowdx9585 &raquo;</TD></TR><TR><TD CLASS="quote">this car sucks i'm sendin it to a garage end or story </TD></TR></TABLE>
lol. Man I feel this way with my car everyday. Once I started messing **** up with my car I feel that it is a piece now. But it will be back one day. So all I can say is keep messing around with your problem if not SHOP time.
Old Jul 13, 2004 | 09:16 PM
Euro-Trash's Avatar
Default Re: D15b help please...i'm swapping now! (DixieRedneck)
i'm going to the shop...they are good and i suck
Old Jul 13, 2004 | 09:30 PM
FERIOkid's Avatar
Default Re: D15b help please...i'm swapping now! (Euro-Trash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Euro-Trash &raquo;</TD></TR><TR><TD CLASS="quote">i'm going to the shop...they are good and i suck </TD></TR></TABLE>
that was me on my friends name and i didn't realize it cause i'm not exactly "all there" right now
Old Jul 14, 2004 | 09:17 AM
FERIOkid's Avatar
somebody...
Old Jul 14, 2004 | 09:55 AM
Discosteak's Avatar
use a d16z6 or d15z1 dizzy
Old Jul 14, 2004 | 08:10 PM
FERIOkid's Avatar
friends grabing me a d16z6 dizzy for free tomorrow and then i'm going to install it and hope to god that everything works otu great
