wich is the right spline for a dx?? someone enlighten me quick!!! tranny problem
Old Jul 12, 2004 | 06:56 AM
91sihatchback
Guest
Posts: n/a
Default wich is the right spline for a dx?? someone enlighten me quick!!! tranny problem
ok i have a 91 si hatchback...my tranny went out so i had to get a 88 dx tranny....we hooked it up with the 88 dx clutch and flywheel and it is working great but i have a huge problemo!
the axles size is different for the tranny..i have a major vibration comming from the car because i used axles from a 95dx...well i need the 88 dx axles...so my problem is when i call autozone for the 88 dx axles i tell her its an 88 1.5 then she says does it have 32 splines or 36 splines....??? which one is it? i need these axles bad because the car is vibrating majorly and iam loosing tranny fluid everywehere someone help!
Old Jul 12, 2004 | 07:06 AM
crx_88_si's Avatar
you will need to use 88-91 DX/Si axles. 1.6 axles should be the same as a DX.
if you really want "dx" axles ask for the spline count on 1.6 axles. they are the same as the DX.
Old Jul 12, 2004 | 07:14 AM
4drEF's Avatar
Keyboard Humorist
Default Re: (crx_88_si)
... could even ask for automatic tranny axles for a DX/LX/EX/Si. That would rule out the hf because I/m pretty sure there weren't any auto hf's.
Old Jul 12, 2004 | 07:53 AM
91sihatchback
Guest
Posts: n/a
they are different part numbers.... the dx and the si are different part numbers for 88-91
Old Jul 12, 2004 | 07:56 AM
crx_88_si's Avatar
ask to physically see both, should be the same splines/length. maybe Si is just beefier.
vinniescrx
Oct 11, 2004 06:36 PM
projectcrx
Mar 26, 2003 09:57 PM
shortyz
Aug 13, 2002 11:48 AM
zcivicz
30
Apr 15, 2002 02:29 PM
charjacq
Apr 11, 2002 04:17 PM
