Valve train upgrade (b18C) rollers..
Old Jul 12, 2004 | 06:51 AM
elementmilwaukee
Guest
Posts: n/a
Default Valve train upgrade (b18C) rollers..
Does anyone make a roller setup for a b18 head? I've already upgraded the valves and springs, but I want to know if there is a better setup like a roller setup that will help increase revs and reduce the chance for float at the same time making the head quieter and less friction? I have seen SOMTHING, but it eliminated the VTEC function it was like a roller rocker setup.. anyone?
Old Jul 12, 2004 | 08:29 AM
elementmilwaukee
Guest
Posts: n/a
Default Re: Valve train upgrade (b18C) rollers.. (elementmilwaukee)
donk.
Old Jul 12, 2004 | 11:00 AM
Wraith_G2IC's Avatar
Default Re: Valve train upgrade (elementmilwaukee)
Unless it is something else very new the ones you are talking about are the "VTEC Killer" cams. Toda make some, and I am sure some others do too. You loose the VTEC lobe, and only make power up high.
http://www.todaracing.com/prod....html
These are race ONLY, so the web site says:
RACING USE ONLY! Makes power from 5000rpm+
TODA dual valve springs are required for this kit. Using non-TODA valve springs may cause damage to the hollow camshafts.
I don't know of any "street" roller setup that retains VTEC. In theory it would be a nice thing to have. That was a hint to you manufactuer guys out there.
Old Jul 12, 2004 | 11:54 AM
elementmilwaukee
Guest
Posts: n/a
Default Re: Valve train upgrade (Wraith_G2IC)
the thing I saw was not a cam but a lifter rather, it had rollers for the surface of the cam lobe. noone else has seen these?
Old Jul 12, 2004 | 12:18 PM
elementmilwaukee
Guest
Posts: n/a
http://www.importperformancepa....html
found them...
Old Jul 12, 2004 | 02:46 PM
Elex's Avatar
those arent for normal cams those are for roller cams when you are basicly removing VTEC.
these cams. http://www.cranecams.com/index...=2022
A13sechatch
Dec 3, 2008 05:30 PM
gsrhatch2356
Oct 20, 2008 08:23 PM
88cerx
13
Jun 15, 2006 06:27 PM
Blanket Jackson
14
Sep 24, 2003 07:16 PM
Hard2Find
Aug 27, 2002 08:00 AM
