question on OEM fpr... dohc vtec vs d series
I just completed my ef hb si b18c1 swap. Well heres the thing. My gsr b18c1 swap did not come with a oem fpr... so what i did was use my stock d16a6 one...
<FONT COLOR="green"> Do you think they have the same psi setting in the diaphram?..
I would hate to be running lean. </FONT>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra6650 »</TD></TR><TR><TD CLASS="quote">i would suggest finding the gsr one i may have on hand ill give it you for 30 shipped if i still have it</TD></TR></TABLE>
so what is stock d16a6 setting and what is stock gsr psi setting?
D16A6 Fuel Pressure: 36-41 psi
B18C1 Fuel Pressue: 39-46 psi
You check fuel pressure when the vacuum line is disconnected from the pressure regulator and the engine is at idle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder »</TD></TR><TR><TD CLASS="quote">D16A6 Fuel Pressure: 36-41 psi
You check fuel pressure when the vacuum line is disconnected from the pressure regulator and the engine is at idle.</TD></TR></TABLE>
so d16a6 36psi at idle and 41psi at idel w/out hose connected?
No, that's the pressure range it should fall in between without the vacuum hose connected to it.
With the hose connected it'll be about 10 psi less at idle, since the engine will be pulling full vacuum, about 20 in hg vacuum is close to -10 psi. With the vacuum line disconnected is the pressure you'd see at wide open throttle, or your max pressure when you are N/A.
hum ... ok since the range on both motors overlap one another it should be fine to run a D16a6 fpr on a stock grs right?
I think you'd be safe to run the A6 regulator. If you have a way to check fuel pressure, I'd check to make sure you are close to the GSR fuel pressure with the A6 regulator.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder »</TD></TR><TR><TD CLASS="quote">I think you'd be safe to run the A6 regulator. If you have a way to check fuel pressure, I'd check to make sure you are close to the GSR fuel pressure with the A6 regulator. </TD></TR></TABLE>
will do i'm ordering my gauge as we speak!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dogfood »</TD></TR><TR><TD CLASS="quote">for how cheap fpr's are why risk it. If you are running lean it'll do more damage than the price of the fpr.</TD></TR></TABLE>
well i'll be ok. right now i'm running on my STOCK ef hb cat and exhaust not to mention i'm still breaking it my clutch so i'm always under 3-4,000rpms hehe
JustAnotherRex
Apr 13, 2008 12:53 PM
aaronhume
Mar 26, 2007 11:43 AM
