how do i take the door panels handel off my manual windows?
Old Jul 12, 2004 | 05:25 AM
flatblk's Avatar
Default how do i take the door panels handel off my manual windows?
Old Jul 12, 2004 | 05:36 AM
crx_88_si's Avatar
you mean the window crank handle?
Old Jul 12, 2004 | 06:12 AM
d357r0y's Avatar
Default Re: how do i take the door panels handel off my manual windows? (flatblk)
look between the handle and the door card, there is a clip. you will need to use a small hook or a small needle nose plier (or the tool that is made for clip removal) and pull it out.
Old Jul 12, 2004 | 06:14 AM
spiceisler's Avatar
Default Re: (crx_88_si)
There is a clip behind the flat part on the crank handle. You'll have to put a skinny flat screwdriver between the panel and the handle and pry a little then you'll be able to see the clip. I usually use a "pick" tool to get the clip out .The flat-tipped screwdriver should be able to pry it out.
Old Jul 12, 2004 | 10:07 AM
MatHadder's Avatar
Default Re: (clean90Si)
the best way to do this is just slide a rag in between the handle and the panel, and if you do it right it will push the clip out.
Old Jul 12, 2004 | 10:11 AM
Full Race A6's Avatar
Default Re: (MatHadder)
Ive broken atleast 4 handles
Just a bitch to get that pin and Im very unpatient
Old Jul 12, 2004 | 10:30 AM
Origin's Avatar
Default Re: (W O T)
lol what? i did it with a screw driver in like 2 sec. i cant see why you keep breaking the handles.
pompom
Feb 28, 2006 04:41 PM
JDMEK206
Jun 27, 2003 02:36 AM
wm5holla
Mar 23, 2003 04:18 PM
DRAG1320ciVHBKsi
Nov 29, 2002 09:50 AM
serious
Sep 6, 2002 04:40 PM
