Squeeky clutch pedal (tried wd-40)
Well my pedal makes a small squeek every time i press it to the floor! Ive tried wd-40 multipul times now and have soaked everything down there... Any advice would be helpful. Is there anything under the hood i can soak with some oil or is it for sure by the pedal, which is where it seems to come from?
it easy to do the clutch cable can be easy spotted under the hood just follow the cable that on the clucth pedal then on to the tranny then take it off and lubicrate it and see what hasppens
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkipMic2006 »</TD></TR><TR><TD CLASS="quote">it easy to do the clutch cable can be easy spotted under the hood just follow the cable that on the clucth pedal then on to the tranny then take it off and lubicrate it and see what hasppens
Just did this on my car. Pulled the cable from the transmission and assembly and pulled as much of the cable out as I could, and then greased the **** out of it. Fixed it right up
philkehn
18
Sep 14, 2006 04:49 PM
