pioneer avic-n1 install
i sell the n1 and have access to the dealer site where i can get the install manual. ill write you tomorrow night. good luck. hopefully someone tomorrow will have it for you. if not, i will.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid Racer. »</TD></TR><TR><TD CLASS="quote">yea the "dealer site" alrite..
all you gotta do is register, and you will have access to the whole line of pioneer</TD></TR></TABLE>
Exactly what he said. I emailed you the pdf file. Hope it helps
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95slowmattic »</TD></TR><TR><TD CLASS="quote">i sell the n1 and have access to the dealer site where i can get the install manual. ill write you tomorrow night. good luck. hopefully someone tomorrow will have it for you. if not, i will.</TD></TR></TABLE>
your L33T status was promptly shot down.
what car is it going into?
do you have an audio console or front console you could put it in?
i stashed my "brain" in the dash, but i dont have NAVI so it didnt have to be parallel
sweet let us know man
one my uncs friends has the N1 is his saturn vue, its awesome <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cootar165 »</TD></TR><TR><TD CLASS="quote">im putting mine into a 94 civic ex coupe. ill post in a few weeks when i get it</TD></TR></TABLE>
the n1 install is just alittle bit harder, you have to run power into the brain this time. and have lots of other wires and **** coming into the deck and out of the deck.
the navi tends to just need a VSS wire... ok well higher end units do, such as the alpine unit. They use the vehical speed sense wire to be able to track where you are if and when the GPS signal is lost. The alpine unit uses the VSS wire combined with gyro's to be able to guess pretty damn accurately when you make a turn, what speed you're going, etc to be able to guess your GPS location even if the signal is cut out for a decent amount of time
how baut the parking brake wire. if I run this cable to the ground cable will that be bad. supposly that will make it so i can play dvd while im driving(for the honey). I love to take road trips and she would love it. from manual
Used to detect the ON/OFF status of the parking brake.This lead
must be connected to the power supply side of the parking brake
switch. If this connection is made incorrectly or omitted, certain
functions of your navigation system will be unusable.
im thinking that if it isn't made right it wont play dvd.
any thoughts
any thoughts
yep, run it to the black chassis ground wire
hybrid gave me the same info for my install and it's fine <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid Racer. »</TD></TR><TR><TD CLASS="quote">yes, it will not harm anything hooking up the green wire to the ground, black</TD></TR></TABLE>
we have installed a ton of theese at work so far this season. the main thing i think that needs improvement is their gps antenna, it is a very slow antenna. otherwise it is a pretty decent unit. it is a great "bang for the buck" unit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECej1 »</TD></TR><TR><TD CLASS="quote">how baut the parking brake wire. if I run this cable to the ground cable will that be bad. supposly that will make it so i can play dvd while im driving(for the honey). I love to take road trips and she would love it. from manual
any thoughts</TD></TR></TABLE>
Just don't get caught driving on the street with the video playing in the drivers view!
when you install the n1, just ground the e brake hook up wire. that will make it so you can do all functions while driving. try that. its easy to hook up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95slowmattic »</TD></TR><TR><TD CLASS="quote">when you install the n1, just ground the e brake hook up wire. that will make it so you can do all functions while driving. try that. its easy to hook up. </TD></TR></TABLE>
welcome to 7 posts ago...
Touch
11
Jun 15, 2003 01:24 AM
