b16a (sir1) swap question
Old Jul 11, 2004 | 05:37 PM
Jerod's Avatar
Default b16a (sir1) swap question
as of right now i am putting my b16 into my 94 civic dx coupe after i put it in and all the plugs and everything were hooked up i tried starting it and it turned over and then just stoped and now won't do anything. i checked all the fuses, i even starter and the motor turned over. what is up with this. anyone ever have this problem???????
Old Jul 11, 2004 | 07:40 PM
Jerod's Avatar
Default Re: b16a (sir1) swap question (Jerod)
anyone......this is sopposedly the easiest swap you can do......
Old Jul 12, 2004 | 02:55 PM
Jerod's Avatar
i'm taking it that nobody has or has ever done a b16 swap in a civi. yep this is the way to answer questions
Old Jul 12, 2004 | 11:20 PM
Redline130's Avatar
Default Re: b16a (Jerod)
Recheck your wiring, make sure you have all your grounds attached securely, and make sure that you are getting spark and fuel.
Old Jul 13, 2004 | 04:38 AM
Jerod's Avatar
Default Re: b16a (Redline130)
UPDATE: i wasn't getting fire to the wires changed out distributers and it cranked!!! i think i have a problem with my under hood fuse box. it clicks alot and somtimes it won't start.
btbomb
Aug 25, 2007 11:28 PM
civic_on_13s
Aug 25, 2003 11:38 AM
conceptEG
May 19, 2003 03:08 PM
