Testpipe & OBD II Assurance
Old Jul 11, 2004 | 05:17 PM
HondaJon's Avatar
Default Testpipe & OBD II Assurance
Been searching, and just wanted an assured answer from the more experienced people in this forum on the subject.
Just got my testpipe from SMSP, to run until I get all of the tuning elements in place, then a high-flow cat will take it's place for tuning.
My car, like many here, is OBD II.
Will running this test pipe with the 2nd O2 sensor just in open air somewhere cause the engine/ECU to make any corrections that would affect the rich/lean mixture of the car??
I'm a little paranoid, and don't know much about the O2 sensors and how they affect our cars, and really don't wish to do any damage to the motor until I get my VAFC in and can tune my car with the high-flow cat on the dyno....
TIA,
Jon
Old Jul 11, 2004 | 05:19 PM
Chris93Si's Avatar
Default Re: Testpipe & OBD II Assurance (HondaJon)
Secondary o2 won't change your a/f ratios but you'll get a CEL.
Old Jul 11, 2004 | 05:21 PM
Smitdog's Avatar
Default Re: Testpipe & OBD II Assurance (Chris93Si)
2nd 02 is strictly Emissions related. Nothing but a CEL basically....
Old Jul 11, 2004 | 05:28 PM
HondaJon's Avatar
Default Re: Testpipe & OBD II Assurance (Smitdog)
So what I've come to understand is that the first O2 sensor has everything to do with adjusting a/f if the engine is running too rich/lean or detonating, thus will not change no matter what you are running (cat or testpipe)??
And the 2nd O2 sensor is just to let emmissions know if you are taking some of the pollutants out of your engine's exhaust??
So the reason why there is a 2nd sensor is just to try and realize a difference between the air flowing into and out of your catalytic converter? Therefore letting us know if our cat is busted and not doing it's job?
Thanks again guys...
Old Jul 11, 2004 | 05:31 PM
HondaJon's Avatar
And then the 2nd O2 sensor cannot put the car into 'limp' mode that will not allow VTEC to engage...correct?
Old Jul 11, 2004 | 05:32 PM
Butterdogg's Avatar
yes to your last question. I am running the same testpipe on the ITR. I have the CEL right now, but it does not go to limp mode. is doing just fine.. I am not worrying about it until I decide which standalone I am going to use.
Eddie
Old Jul 12, 2004 | 11:10 AM
Ill's Avatar
Ill
Someone else chime in here. I think I'm running rich, and won't know until I get the tunign stuff installed next week. I was thinking the rear O2 was the cause, but this makes me think it's the front O2. Can anyone confirm?
I was throwing the CEL for a bit before I discovered the problems the former owner of my R left me with the exhaust (long story). It did not go into limp.
Old Jul 12, 2004 | 12:38 PM
iperez's Avatar
Same situation here .. JDM 4-1, test-pipe, Greddy EVO2 ... No Cat.. I have both sensors installed and I get the CEL but no noticeable problem with power ..
Old Jul 17, 2004 | 10:27 PM
K20DC2R's Avatar
Default Re: Testpipe & OBD II Assurance (Ill)
the only time the car goes into limp status is when it has a misfire or primary o2 problem.... the secondary o2 is just to ensure the cat is doing its job.
Old Jul 18, 2004 | 09:43 AM
danny98r's Avatar
Default Re: Testpipe & OBD II Assurance (VtecWhore)
get a t1r resonated testpipe and make a o2 bung and u wont it wont throw a CEL
BoldFart16
Engine Management and Tuning
12
Mar 12, 2011 06:09 AM
91c-rex_si
Oct 3, 2010 11:36 AM
Joel_MN
Apr 1, 2004 11:15 PM
Pikachu
Oct 22, 2003 05:36 PM
Qwikrex
Aug 1, 2002 05:50 PM
