Need Help with DSM Injectors
i am trying to upgrade my injectors and i was thinking about getting some 450cc dsm injectors, what would i need to make thse work on my obd2 gsr? is there a better way to go? I wanted to get the dsm injectors because they are cheap, if anyone has had any problems with their dsm injectors please let me know.
btw im going to be running the stock ecu for a while with a 12:1 fmu not sure if that matters but just thought i should let you guys know
if u plan on going with 450cc injectors then you shouldnt get 12:1 fmu.. more like 4:1 or 6:1 at most... 12:1 and 450cc's you will be running like rediculously rich where it will be a problem.
so if i have a 12:1 fmu i should even get injectors? maybe i should just wait till i can get hondata or something
What about a fuel pump? will i need that in order to run my turbo? cause someone told me that if i run lean i can seriously hurt my engine
pelotudo
Sep 8, 2002 06:29 PM
