compression test results: pre obd b16
Old Jul 11, 2004 | 02:32 PM
b16_madman's Avatar
Default compression test results: pre obd b16
#4:198
#3:210
#2:209
#1:210
I know I should've had the motor warm, but it was already closet to 100* outside, so that's close enough. The vtec manual said (new) 185 psi, give or take 28 psi. I guess the b16 is doin good? Or do I gots lots of carbon?
Old Jul 11, 2004 | 03:12 PM
crx_88_si's Avatar
Default Re: compression test results: pre obd b16 (B16_madman)
good numbers!
Old Jul 11, 2004 | 03:57 PM
krazie1's Avatar
BANNED
Default Re: compression test results: pre obd b16 (crx_88_si)
wow it is close to that temp here in so cal too
and well maybe u got carbon in the #4 cyclinder but besides that very good number for a stock b16a or with pr3 pistons
Old Jul 11, 2004 | 05:03 PM
b16_madman's Avatar
Default Re: compression test results: pre obd b16 (krazie1)
pr3 pistons, or pwo...? It's the xsi swap, so it's the pwo, if I member that's my ecu at least, but all of it came from the same car.
Now to figgur out why it only runs a 15.3 round here Driver's suckage I suppose.
Old Jul 11, 2004 | 05:10 PM
japrex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazie1 &raquo;</TD></TR><TR><TD CLASS="quote">wow it is close to that temp here in so cal too
actually they always say to allow up to 15 psi difference for #4 cyl so actually his numbers are very good and up to spec.
crxfreak1117
Oct 13, 2006 12:22 PM
eg6style
Nov 10, 2004 09:40 AM
^jefs0ng
Dec 2, 2003 03:28 PM
TYspeK EH2
11
Jul 19, 2003 05:52 PM
Bizarre
May 2, 2003 10:10 AM
