oil gauge
Old Jul 11, 2004 | 12:43 PM
Civichatch27's Avatar
Default oil gauge
Anybody got pics on how to install a mechanical oil gauge on a 91 hatch? PLease help!!!!!!!!!
Old Jul 11, 2004 | 12:48 PM
krazie1's Avatar
BANNED
Default Re: oil gauge (Civichatch27)
what exactly u need to know
the whole process
well u are going to have to tap into block or use the low oil pressure switch honda has in the block of ur currect block
that is where I tapped mine at used some npt fittings I got a home depot or lowes or any hardware store
and then run the regular plastic line which I wouldn't recommend as if u crack it or bent it and leaks will be everywhere inside
thent he wiring should be pretty simple if u have the instructions if not u will need three wires
one for power, another for ground and the third for switched power for the light in the gauge
if u still confused u can ask me
as I know I kinda of wrote it quickly
Old Jul 11, 2004 | 01:14 PM
Default Re: oil gauge (krazie1)
the tapping and plumbing into block is whats kinda spooks me...thats why i would like some pics or details.
Old Jul 11, 2004 | 01:43 PM
crx_88_si's Avatar
go to http://www.tunertoys.com and get the oil fitting.
then just run the necessary tubing.
If I were you i'd go w/ a elec one. The mechanical one requires HOT PRESSURIZED oil to go to the back of the gauge! if that leaks it'll burn!
Old Jul 11, 2004 | 01:47 PM
KaoticSnow's Avatar
just get and elec one. I agree on this one
Old Jul 11, 2004 | 05:31 PM
beavis's Avatar
electronic is teh way to go, mechanical the oil line goes to the back off the gauge. and if the fitting on the line to the gauge breaks you will probablly get oil all over the inside of you car.
Built4Battle
Nov 2, 2011 11:39 AM
lancerkid06
Jan 7, 2008 07:17 PM
oo3
Jun 3, 2006 10:00 PM
2kgs-R
Apr 4, 2002 05:37 PM
