Can anyone tell me how to remove the glove compartment...
Old Jul 11, 2004 | 10:55 AM
99IntegraGS's Avatar
Default Can anyone tell me how to remove the glove compartment...
from a 1998 Accord Coupe? I don't know much about these cars, but I'd assume the dash is similar to the same generation sedan.
Anyone run a large power cable from the battery to amps in the trunk? I'm trying to get through the firewall with a 4ga cable and seem to have found a hole that's not in use. I pulled the plug from the hole and can't seem to find where the hole comes out on the interior side.
I'm trying to remove the glove compartment to see if it will help me find the hole on the interior side, but removing the 4 obvious screws doesn't seem to be enough to remove the glove compartment.
thanks in advance...
JD
Old Jul 11, 2004 | 11:26 AM
bill-71SS's Avatar
Default Re: Can anyone tell me how to remove the glove compartment... (99IntegraGS)
2 screws on latch,2 onder the black covers on each side,then take off the lower panel and you will see 4 more to take out,pull it up and out
Old Jul 11, 2004 | 11:44 AM
Default Re: Can anyone tell me how to remove the glove compartment... (bill-71SS)
Thanks!
I'll give it a try later on this evening... it's just too damn hot (94º) and humid (44%) right now. I'm not sure I believe those numbers...
Honda EK
Jul 28, 2008 08:27 PM
yomayo
Nov 22, 2006 05:11 PM
95sivee
Audio / Security / Video
14
Jan 14, 2006 09:11 PM
aburn
Jun 16, 2002 08:43 PM
2qwik2nv
Apr 10, 2002 05:37 AM
