Anyone out there making over 180whp take a look
Old Nov 21, 2001 | 05:35 PM
ic108's Avatar
New User
Default Anyone out there making over 180whp take a look
To keep things short and simple here it is. I do NOT understand this and want some feedback. Why is it that nobody thinks that this set up will yield me 180whp. Is it because i have a GSR and not an R??????? Here is the set up
2000 GSR
AEM ITR CAI, cam gears, u/d pulleys, DC JDM 4-1, test pipe, greddy SP exh, skunk2 intake manifold, 64mm TB, FPR, P28 ECU, AFC.......about to install USDM ITR cams, valve train, valves and pistons along with a Mugen head gasket.
Conclusion: SO basically, i have a GSR/TypeR with , 11:1:1 compression AND so i here the GSR head flows better then the TypeR. I have been told 175whp if i am LUCKY by a few reputable sources. I have seen dyno plots of GSR's running less extensive mods making 180whp with stock 10:0:1 compression. Why is mine any different???? Please anyone, tell me if i am missing something. I have forked out a lot of cheese and need to know why tuners are telling me this. Maybe i need to upgrade my AEM license plate frame to a Greddy frame or something. Thanks
Old Nov 21, 2001 | 05:36 PM
Ibuprofen's Avatar
Default Re: Anyone out there making over 180whp take a look (ic108)
why dont u just go dyno your car
Old Nov 21, 2001 | 05:39 PM
ic108's Avatar
New User
Default Re: Anyone out there making over 180whp take a look (JDM_DC2R)
i will as soon as i get the cams, pistons, and valve train installed.
Old Nov 21, 2001 | 05:47 PM
sackdz's Avatar
i doubt the skuck mani, the larger TB will help you much, not with ITR cams.
[Modified by sackdz, 9:50 PM 11/21/2001]
Old Nov 21, 2001 | 06:14 PM
99ITR_SC's Avatar
Default Re: Anyone out there making over 180whp take a look (sackdz)
Is it just me or is something strange going on here? I just posted, and my post disappeared, as well as the inital message was edited but there is not edit history.
Am i losing it?
Old Nov 21, 2001 | 06:32 PM
Flux's Avatar
Or just throw it away...
stick's Avatar
i dont think u know what ur talking about:
skunk2 mani is similiar in design to the ITr mani and ITR TB is larger than GSR by 2mm and im sure his is at least 64mm. this is a great combo with ITR cams.
i think u will see mid 180's with ur set up. just tune the hell out of it like u should with anything on a dyno
Big Phat R's Avatar
Default Re: Anyone out there making over 180whp take a look (99ITR_SC)
Am i losing it?
Definitely
Old Nov 21, 2001 | 06:53 PM
99ITR_SC's Avatar
Default Re: Anyone out there making over 180whp take a look (Big Phat R)
Am i losing it?
Definitely
Coming from someone that has already lost it I guess you'd have a pretty good idea.
Old Nov 21, 2001 | 07:06 PM
RJL's Avatar
RJL
New User
180 whp is cake with that set up. With the Skunk Manifold and ITR cams alone that should get you close to 20 hp. Stock gsr put down anywhere from 148-158 to the wheel. Plus your other mods including pistons (which if they are JDM ITR will give you about 11:5:1 CR) You are definitly in the 180s. Your gonna need to tune though, nothing is plug n' play with that setup.
Old Nov 21, 2001 | 07:13 PM
MiraiZ's Avatar
ehehehe....GSR/Type R....boy, you're really asking for a flaming!!
Old Nov 21, 2001 | 07:21 PM
RJL's Avatar
RJL
New User
Default Re: Anyone out there making over 180whp take a look (MiraiZ)
How dare you mention a GSR in the same sentance as a Type R, get the hot suit flames are coming! Just kidding
Old Nov 21, 2001 | 09:47 PM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Default Re: Anyone out there making over 180whp take a look (Badboy01GSR)
BadBoy: Wow. I've ****NEVER**** seen a stock OBD2r2 GS-R put down 148, let alone 158. Consider that ITRs put down 160-165 stock and I think your numbers are off a bit.
[Modified by Dave-ROR, 1:48 AM 11/22/2001]
Old Nov 21, 2001 | 09:52 PM
VaporTrail's Avatar
New User
You should be able to see 180whp with that setup. I've done a VERY similar setup on an old tired motor with no valve upgrades (free power there) pull 175 to the wheels on my dyno. So a strong running, more modified motor should see that easily and then some. If you are interested in some dyno time, BTW, I am local and can assist you. Thanks.
Old Nov 21, 2001 | 09:58 PM
b00st-0wnz's Avatar
Default Re: Anyone out there making over 180whp take a look (VaporTrail)
**** John.. I didn't even see that.
IC: come to the dyno day to get a baseline for tuning. Jan 12th. See the "florida people" thread for more info
Old Nov 21, 2001 | 09:59 PM
RJL's Avatar
RJL
New User
Default Re: Anyone out there making over 180whp take a look (Dave-ROR)
didnt know he was obd 2, but I have seen dynos of a 96 GSR that was putting down 152 stock, timing at 18 BTDC. And there was a dyno on here of a 2000 GSR converted to OBD1 making 150 or 151 WHP. I also saw on this board two ITRs that were putting down 165+ whp stock.
[Modified by Badboy01GSR, 7:12 AM 11/22/2001]
Old Nov 21, 2001 | 10:00 PM
VaporTrail's Avatar
New User
Dave - it's the first thing I look at under a post that interests me...
yes, but he listed a P28 ECU, which means hes probably converting to OBD1. Definate for that
[Modified by VaporTrail, 2:01 AM 11/22/2001]
Old Nov 21, 2001 | 10:03 PM
b00st-0wnz's Avatar
Yep, I'll be OBDI soon too.. once FAST94GSR sells me that fuggen ecu! hehe Hopefully by the dyno day.. oh yeah John.. uhmm.. we'll want to clear out the room for my car.. the exhaust will be.... loud....... and pointed at the side wall..
Old Nov 21, 2001 | 10:04 PM
Dirty GS-R's Avatar
New User
Yeah, I'm not sure where you got those numbers either. I've seen some stock GSR's dyno at 135whp. I'd say most are around 140.
Old Nov 21, 2001 | 10:05 PM
VaporTrail's Avatar
New User
Awesome. Good thing you don't drive it on the street, my buddy has a turn down on his GSR that's painful. Which "side wall" will it be pointing to? I assume the side closest to the dyno...damn we got off subject on this real quick!
Old Nov 21, 2001 | 10:06 PM
ic108's Avatar
New User
i am currently running an OBD-1 ECU. compliments of kenji
Old Nov 21, 2001 | 10:09 PM
b00st-0wnz's Avatar
John: Actually.. it's the daily driver right now.. with the 450lb springs up front, 600lb in back and r-compounds. I figure if the exhaust is loud enough I wont hear the tires anymore And yeah, it'll be coming out the pass side in front of the rear tire. I might put a turndown on it for the day.. we'll see. Once I finish the buildup of the beaters motor, the teg wont be driven much again
Old Nov 21, 2001 | 10:10 PM
b00st-0wnz's Avatar
ic: kenji is just a mullet head FREAK!
Old Nov 21, 2001 | 10:19 PM
AllMotorITR's Avatar
New User
I'm suprised my boy hasn't posted yet..
He's got bolt ons, Toda Bs, toda camgears.. puttin down 182whp on his last dyno...
ic108's Avatar
New User
so you are the guy i told kenji about. i told him that someone on honda-tech was talking trash about him calling him a mullet head and ****. i thought it was dave at acura and kenji called up there questioning him or something
