Fuel Pump?
Old Jul 11, 2004 | 10:19 AM
dabigrog's Avatar
Default Fuel Pump?
92 accord Was running last night
this morning it wouldnt crank. turns over but wont start.
have spark.
noticed that the fuel pump doesnt prime/buzz when key is turned on.
and there is no fuel to Fuel rail.
Voltage meter read 3 volts at wires going into fuel pump
is the fuel pump bad? how to test?
any help greatly appreciated.
Old Jul 11, 2004 | 10:22 AM
hondadude's Avatar
Default Re: Fuel Pump? (dabigrog)
Go to the main relay up under the dash above the cruise control unit.
The Yellow wire is the output to the fuel pump. pin #4
Old Jul 11, 2004 | 10:24 AM
dabigrog's Avatar
Default Re: Fuel Pump? (hondadude)
1992 accord lx
Old Jul 11, 2004 | 10:28 AM
hondadude's Avatar
Fuse #2 of the dash fuse box is the power source
Old Jul 11, 2004 | 04:40 PM
carolinaACCORD's Avatar
More than likely it is a faulty main relay.
In that generation Accord, and also the 4th generation Preludes, the main relay would begin to malfunction after a few years. This due to the components inside expanding and contracting with temperature changes. It will eventually break the contacts inside the relay, and will intermittently cause it to act quirky.
A new relay is about $60 from Honda.
Old Jul 11, 2004 | 06:29 PM
dabigrog's Avatar
Default Re: Fuel Pump? (carolinaACCORD)
thx. tested main relay, its workin as far as i can tell.
gettin 12 volts back to wire harnest for fuel pump
puttin new fuel pump on tom. hopefully it works =/
ty for help.
Old Jul 12, 2004 | 06:37 PM
dabigrog's Avatar
k im wrong.
went outside tonight and car started right up.
i think it is the main relay.
atleast its cheaper to fix. =/
toddkeeb
Aug 5, 2013 02:11 PM
NorthCountry
Jul 13, 2011 01:38 PM
civic91sief
Nov 5, 2009 10:59 PM
Voidus
Aug 24, 2009 02:18 PM
YodajdmEK4
Oct 3, 2005 09:24 AM
