sizing denso plugs?
Old Jul 11, 2004 | 09:50 AM
HondaAccordSiR's Avatar
Default sizing denso plugs?
my car came stock with NGK iridiums. 03 Accord. NGK does not make a plug two steps colder that's still an iridium plug, so I've moved to denso. I'm trying to size their iridium plugs and the scale has me a little confused. tech's not open right now and I want to know.
I'm looking at IK20 as stock replacement, is the IK22 2 steps colder or the IK24? Their scale raises by even numbers except for a special IK21 plug listed. That IK21 is throwing a wrench in the scale.
http://www.iridiumpower.com/identifyplugs.htm
Old Jul 11, 2004 | 09:53 AM
2FastxEg's Avatar
if ou pick up the next issue of OverRev Magazine at your nearest race shop, it will supply you with the exact information you are looking for. To answer your question, this is directly quoted from the tech guru at denso, you only need to go one step colder if you are gaining about 75-100 horsepower. so for every 75-100 hp you go a step colder. Look up your stock replacement part number and then go a step colder form there...
Old Jul 11, 2004 | 09:54 AM
Default Re: (2FastxEg)
thanks I was going 2 steps for 100 hp gain, but if that's true cool.
Old Jul 11, 2004 | 01:16 PM
2FastxEg's Avatar
yeah one step lower would be perfect..... two steps down will foul up your spark plugs for sure
Old Jul 11, 2004 | 02:39 PM
DRAGLS's Avatar
Default Re: sizing denso plugs? (HondaAccordSiR)
ngk does have different heat ranges for your car in iridium! Where have you been looking?
Old Jul 11, 2004 | 03:14 PM
Default Re: sizing denso plugs? (DRAGLS)
off their website and several car parts stores referencing their books. stock is a IZFR6K-11, so I would want a NGK IZFR**7 or 8**K-11
Old Jul 11, 2004 | 03:21 PM
DRAGLS's Avatar
you can run any of these:
bkr6eix-6418 hotter
bkr7eix-2667
bkr8eix-2668
bkr9eix-2669 coldest
Old Jul 11, 2004 | 03:43 PM
are those NGK's? and are they iridium?
thanks for the info
Old Jul 11, 2004 | 03:45 PM
DRAGLS's Avatar
yes they are NGK and they are iridium!
Old Jul 12, 2004 | 08:13 AM
2FastxEg's Avatar
denso is the best spark plug you can get.... the iridium electrode is a lot smaller and is a lot stronger than ngk's... theres a reason why a lot of pros run the Densos and not the ngk's
Old Jul 12, 2004 | 02:47 PM
called NGK tech, excellent help. and thanks DRAGLS, you were on the money.
Old Jul 12, 2004 | 05:08 PM
DRAGLS's Avatar
Default Re: (HondaAccordSiR)
glad to help, I have their catalog, u should call back and order one their FREE!
thats were i get all my plug info
Old Jul 15, 2004 | 08:51 AM
2fastxeg,
were you referring to the nitrous article in overrev? nothing new there, but I seem to missing something mentioning plugs.
thanks for the info
Apr 28, 2012 10:26 PM
91akira
Mar 12, 2010 08:23 AM
Chiller
Oct 29, 2004 08:18 AM
Aeka GSR
Dec 5, 2003 10:14 AM
Casey
Mar 19, 2002 07:00 PM
