Honda S2000 Honda S2000
Buddy Club Racing Spec Coilover
Old Jul 11, 2004 | 09:33 AM
DjDrift's Avatar
Default Buddy Club Racing Spec Coilover
Installing a set of Buddy Club Coilovers w/ pillowball mounts today. Not sure if I use both mounts (the pillowball and the one that comes on it) or does the pillowball just sit on the spring? Washers or no washers?....Instructions are in japanese and I cant find a diagram anywhere. Also what did you do about the stock bolts being to big for the bottom mounts? Weld new bolts on or did you find the right size bolt at a hardware store? Anybody have these and can help me out?
Modified by DjDrift at 2:22 PM 7/11/2004
Old Jul 12, 2004 | 08:55 PM
DjDrift's Avatar
Default Re: Buddy Club Racing Spec Coilover (DjDrift)
Called Buddy Club today the pillowball mounts do replace the original mounts. Didnt ask about the washers but I did use both and so far no problems. I cut off the tac welded nut and went to the hardware store for the right size nut. Assembled correctly the coilovers will look like this
[IMG][/IMG]
sackofrice
Nov 14, 2008 10:15 AM
_Bug_
Aug 6, 2003 05:30 AM
gubo22
Nov 1, 2001 12:18 AM
