Correct ball joint removal
Old Jul 11, 2004 | 09:01 AM
d357r0y's Avatar
Default Correct ball joint removal
Smack pad with big hammer = ball joint pops free
Engine hoist rolls = custom body work
Old Jul 11, 2004 | 09:26 AM
kulangot's Avatar
Default Re: Correct ball joint removal (d357r0y)
no **** ?lol.
Old Jul 11, 2004 | 10:50 AM
markleavey's Avatar
Man, I wish mine was that easy, I wasted 5 hours yesterday on my SiR trying to remove the balljoint and I used a lump hammer and ball joint splitter!!!
Mark
Old Jul 11, 2004 | 11:19 AM
Origin's Avatar
Default Re: Correct ball joint removal (markleavey)
oh d357r0y you are so smizzart
Old Jul 11, 2004 | 12:13 PM
HamiltonRex's Avatar
Default Re: Correct ball joint removal (Origin)
I had to use a pickel fork in an impact hammer.
-Eric
Old Jul 11, 2004 | 01:21 PM
Motorhead_AZ's Avatar
I used a pickle fork with a regular hammer when I changed my axle. It took me 15 minutes from the second I put the car on jack stands to the second I dropped it and tightened the lug nuts
Old Jul 11, 2004 | 01:42 PM
Origin's Avatar
Default Re: (Motorhead_AZ)
everytime i use a pickle fork i destroy the boots. what am i doing wrong?
Old Jul 11, 2004 | 01:46 PM
Chronic_SMOKE's Avatar
i like using the fork, its alot faster than just hammering alone
Old Jul 11, 2004 | 02:14 PM
d357r0y's Avatar
Default Re: Correct ball joint removal (HamiltonRex)
Pickle forks **** boots. Honda put those pads there so you could whack them and the ball joints would pop out. it only takes a couple of good whacks, not to mention then you can save your 15 bucks that the pickle fork woulda cost ya and get some alone time in a XXX video booth.
Old Jul 11, 2004 | 02:24 PM
Origin's Avatar
so i would assume to get the outer tie rod ball joints out of place you just hit the rod ? or is there a better place to smack it? ive torn those boots as well. what happens if you don't replace them? problems later on?
Old Jul 11, 2004 | 02:28 PM
Rywire's Avatar
I just jam a crowbar between the lca, and the knuckle, and yank up. No grease loss, and a 10 second job, it works great...but scarry the 1st time(loud pop). Ryan
Old Jul 11, 2004 | 02:58 PM
wtsexton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d357r0y &raquo;</TD></TR><TR><TD CLASS="quote">Honda put those pads there so you could whack them and the ball joints would pop out. </TD></TR></TABLE>
Not to whack them. If you notice there is one on each side and the bolt has a hole in the middle the correct way is to use a puller.
So no you are NOT doing it the CORRECT way.
Old Aug 16, 2004 | 05:25 PM
90LSpimpin's Avatar
Default Re: Correct ball joint removal (wtsexton)
Hell, it may not be the right way, but I can attest to the fact that it works like a charm. Doin my clutch right now and we musta been hammerin at that ball joint for about 2 hours. Tried with the fork and then went wit this method. Popped out in about 10 more mins of hammerin.
Old Aug 16, 2004 | 05:34 PM
kshymkiw83's Avatar
Default Re: Correct ball joint removal (WeaponRex86)
i just pulled my axles and i sat there for an hour or so tryin to pop the LBJ's. went out got the fork and oppped em loose in about 20 seconds. Use the fork, it is the easiest thing to use
Old Aug 16, 2004 | 06:31 PM
RapeV-8's Avatar
on my STD there is a ring on my hub??!! i removed it in order to pop the ball joint off... now do i have to put the ring back on the hub?
Old Aug 16, 2004 | 06:34 PM
7808's Avatar
Default Re: (igotcrx)
peel up the rubber, shove the fork in, beat it till it pops out.. no harm done.
Old Aug 16, 2004 | 08:18 PM
Driven's Avatar
Default Re: (fuctup)
...several methods of removing ball joint:
1. remove LCA and entire knuckle. with it out, hammer it off.
2. use an actual ball joint separator
3. place a large screwdriver between the axle and the LCA, raise/lower the suspension until it pops.
Old Aug 16, 2004 | 08:42 PM
blah13's Avatar
Default Re: (Driven)
From easy to hard.
1. Whack it with hammer, may or may not work.
2. Get your pickle fork, for those who tear boots grease the fork pretty good before trying.
3. Ball joint sperator, what the tabs on the side of the LCA are made for. Should work 100%.
4. Remove the whole deal and beat the **** out of it.
If all fails, buy a whole new assembly, you *****.
Old Aug 16, 2004 | 09:07 PM
Mires's Avatar
Default Re: Correct ball joint removal (kshymkiw83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kshymkiw83 &raquo;</TD></TR><TR><TD CLASS="quote">i just pulled my axles and i sat there for an hour or so tryin to pop the LBJ's. went out got the fork and oppped em loose in about 20 seconds. Use the fork, it is the easiest thing to use </TD></TR></TABLE>
Umm, maybe I should get me one of those.
Old Aug 16, 2004 | 10:22 PM
ComputerJLT's Avatar
one of those i guess pickle forks in an air hammer = removing the ball joint in 20 seconds!
I fought for hours with one of mine; then got that fork and threw it in my air hammer; 20 seconds later the bitch was out. I didnt know if i should be happy it was out or mad that i wasted so much time before
Having the right tools makes life so much easier!
Old Aug 17, 2004 | 04:00 AM
skellator_thoj's Avatar
Default Re: Correct ball joint removal (ComputerJLT)
nice info..
Old Aug 18, 2004 | 04:09 PM
92integra_gs's Avatar
you just have to put the pickle fork in the right spot for the boot not to tear... i have done this about 10 times... and i am very precise where i place the pickle fork and still havent rip the boot yet...
Old Aug 18, 2004 | 05:07 PM
Superhatch's Avatar
Default Re: (92integra_gs)
Stick a fork in it y0!
Hasen't failed me yet.
Old Aug 18, 2004 | 06:26 PM
JapJunkie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d357r0y &raquo;</TD></TR><TR><TD CLASS="quote">Smack pad with big hammer = ball joint pops free
works all the time, sorry about the dent, that type of **** happens all the time
C_Rock77
Aug 27, 2008 11:19 AM
B18EG6
Suspension & Brakes
21
Oct 13, 2006 05:15 AM
spidermancivic
Sep 7, 2004 08:28 AM
gumbybum
Jan 31, 2003 11:11 AM
civcexcoupeblack
12
Sep 22, 2002 02:27 AM
