ls cluster into 91 civic hb?
Does any know where i can get a how to on this? I have a ls cluster from a 90 teg that i would like to install into my hatch, but can't find a write up for it.
others would say search
, but I'm not others
http://www.4thgenerationcivic.com/
look at aftermarket swaps, you'll find it there, btw I did it & its noice
also did the crx dash swap, projectors ect. good reference.
there may be some other swaps here but this is where I got mine from
heres some vids on mine @ nite,
http://www.we-todd-did-racing....DE%3D
the tach was de-activated on one of the vids cuz I have a toggle switch to run my vtec
otherwise they're bigger than the stock gauges & mine is an automatic besides
otherwise they're bigger than the stock gauges & mine is an automatic besideshttp://www.we-todd-did-racing....DE%3D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDACIVICWAGON.COM »</TD></TR><TR><TD CLASS="quote">others would say search
Did your speedo work? Cuase mine worked before the swap and now its not working? I'll have to find someone that has a ls teg so that i can test the cluster it self maybe the speedo on it is bad? or can it be my cable?
the speedo on my 1st cluster didn't work cuz the cable came out, plugged back in now aok. Check to see that it didn't disconnect. good luck
hmm, don't know. I would suggest that if the center cable is 'pushed in' try using small needle nose pliers & gently pull the inner driver cable out no more than an 1/8th" until it can engage the speedo properly.
How did it get pushed in?
i have no idea how that happened? also i think i messed up on the wiring cause my ecu is throwing out code 15. and did the needled light up for before you installed the reverse indiglos
LickyMYwalker
Aug 31, 2008 12:21 PM
CalhounBoi
Sep 1, 2005 10:52 PM
