is it safe to drive?
Old Jul 11, 2004 | 06:35 AM
Chris_Bye's Avatar
Default is it safe to drive?
i have a 90 computer in my 91 integra. In a previous post i made, i stated that the check engine light is on because of ecu code 13: atmospheric pressure sensor.
Another member replied and told me that the 90 PA is external, and the 91 is internal
I just need to know if it is safe to drive around without harming anything! Please help!
Old Jul 11, 2004 | 07:36 AM
Chris_Bye's Avatar
Default Re: is it safe to drive? (91ntegra)
no one knows?
Old Jul 11, 2004 | 08:14 AM
slo2kgsr's Avatar
You should be fine the sensor mesures the outside air to give a correct air fuel mixture. Higher altitude less air lower more air. The car will just go into a fail safe mode and you should be able to drive it. Worse possibility is you will be running rich and get bad gas milage other then that your fine.
Old Jul 11, 2004 | 08:43 AM
Chris_Bye's Avatar
Default Re: is it safe to drive? (tegraLS97)
thanks
nelsond
Jun 13, 2006 06:21 PM
sneezyh22a4
Dec 1, 2004 08:16 AM
tegtip
May 22, 2003 09:20 AM
austrian type-R
Sep 17, 2001 12:41 PM
