close ratio transmission
Old Jul 11, 2004 | 01:54 AM
atermizi's Avatar
Default close ratio transmission
guys i've been searching for a while for an article than can help me understand how does a close ratio tranny works..if anybody can help post a link or explain it to me..
Old Jul 11, 2004 | 02:30 AM
WangChung's Avatar
Default Re: close ratio transmission (atermizi)
mkay. there is a numerical ratio for each gear in a gear box. the higher the number, the shorter the gear. so if first was 2.3 then second would be about 1.9. when the these ratios are very close, numerically, it is considered to be a close ratio transmission. close ratio transmissions are often used to keep an engine within its powerband, by not letting revs drop below a certain point. take d-series motors for example:y7 trannies are geared long as ****, for better highway gas-mileage while y8/z6 trannies(relatively close ratio) are geared shorter to keep the rpm from dropping out of Vtec. i hope i didnt butcher that too bad.
Old Jul 11, 2004 | 02:44 PM
vladd's Avatar
Default Re: close ratio transmission (WangChung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WangChung &raquo;</TD></TR><TR><TD CLASS="quote">mkay. there is a numerical ratio for each gear in a gear box. the higher the number, the shorter the gear. so if first was 2.3 then second would be about 1.9. when the these ratios are very close, numerically, it is considered to be a close ratio transmission. close ratio transmissions are often used to keep an engine within its powerband, by not letting revs drop below a certain point. take d-series motors for example:y7 trannies are geared long as ****, for better highway gas-mileage while y8/z6 trannies(relatively close ratio) are geared shorter to keep the rpm from dropping out of Vtec. i hope i didnt butcher that too bad. </TD></TR></TABLE>
except that y8/z6 trannies still let the engine drop out of vtec after redlining
Old Jul 11, 2004 | 11:20 PM
WangChung's Avatar
Default Re: close ratio transmission (civicdxtyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdxtyper &raquo;</TD></TR><TR><TD CLASS="quote">
except that y8/z6 trannies still let the engine drop out of vtec after redlining </TD></TR></TABLE>
i was just testin ya!
Old Jul 12, 2004 | 03:17 AM
atermizi's Avatar
thanks. any article anywhere?
LoudLude
11
May 13, 2006 02:08 PM
gray_civic_coupe
Jan 8, 2006 12:49 PM
rdeezy78
Dec 28, 2005 04:31 PM
Edw-R
Oct 26, 2004 09:34 PM
Javier
Aug 12, 2003 11:42 PM
