DOHC ZC cant get check eng. light to go off
Old Jul 10, 2004 | 11:02 PM
crxzcracer's Avatar
From: Murfreesboro, Tennessee, United States of America
Default DOHC ZC cant get check eng. light to go off
a while back i did a dohc zc swap in a 91 hf crx
it runs great but i cant get the check eng. light to go off it is throwin the egr value code cuz the zc dosent have one what do i do?
Old Jul 10, 2004 | 11:06 PM
ServiceAdvisor's Avatar
Thats strange, because the only light I throw off is the VSS which is due to a bad cluster gauge. Are you sure what code your throwing? Are you positive that you know how to retrieve a code? Are you sure your ZC has no EGR Valve? - Darrell
Old Jul 10, 2004 | 11:11 PM
crxzcracer's Avatar
Default Re: (OldSiHatch)
well i thought the 91 and older zc didnt have them but then agin i am a dumb ***
what are to codes?
is there a list out there
o and i am running the 89 tag ecu
Old Jul 11, 2004 | 07:37 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: DOHC ZC cant get check eng. light to go off (crxzcracer)
I could be wrong, but the only way you'll throw an EGR code is if you are using an ECU from a car that had EGR on it.
If you're using an 86-89 Integra ECU from a 5-speed model it shouldn't be throwing an EGR code. If it is then that's the first I've ever heard of the Integra 5-speeds having EGR. Some autos did, but not 5-speeds to my knowledge.
Old Jul 11, 2004 | 07:41 AM
bluecrxsi's Avatar
im pretty sure jdm motors dont have egr valves. like my b16 doesnt have.
Old Jul 11, 2004 | 07:54 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: (bluecrxsi)
Yeah I'm pretty certain the engine itself doesn't have EGR, but what I'm saying is that the ECU determines whether or not you'll be throwing an EGR code.
Question:
Exactly what check engine code(s) do you have?
Old Jul 11, 2004 | 03:12 PM
crxzcracer's Avatar
Default Re: (B18C5-EH2)
it a code 19 i just checked it
i was told that was ecr but it seems not to be any one no what that is?
Old Jul 11, 2004 | 03:36 PM
crxzcracer's Avatar
Default Re: (crxzcracer)
bump for a code 19
Old Jul 11, 2004 | 03:46 PM
ek_99_SiR's Avatar
get an si ecu and problem solved
Old Jul 11, 2004 | 03:55 PM
4drEF's Avatar
Keyboard Humorist
ECU codes
http://tech.hybridgarage.com/tech/codes.html
.. or just plain out search on the net
http://search.yahoo.com/search...=ieas
19 is for an automatic tranny ECU.
Old Jul 11, 2004 | 04:17 PM
crxzcracer's Avatar
Default Re: (4drEF)
well i was told it was out of a 5 speed teg
the light was also on when i ran it with the hf ecu now it was a 5 speed for sure
(but a that time the speedo cable didnt work)
Old Jul 11, 2004 | 04:25 PM
4drEF's Avatar
Keyboard Humorist
You can run an auto ECU in a manual car without any problems.
Check engine lights come on for all sorts of different reasons. What code was the HF ECU showing? I would BET that it was for the VSS since the speedo cable wasn't in. Speedo cable also runs the VSS. I doubt it was the code 19 that you have now.
Old Jul 12, 2004 | 08:55 AM
crxzcracer's Avatar
Default Re: (4drEF)
no its a code 19 i check it came back in and posted it
i will put the hf ecu on it and see what code comes up
maybe i need to reset the ecu
how long do i leave the battair dissconneted to re set it or ill just unplugging it reset it.
Old Jul 12, 2004 | 09:06 AM
crx_88_si's Avatar
ok..
if you use that teg ecu you will throw code 19 cuz it's an auto ecu
if you use the HF ecu you will throw EGR code cuz the ZC doesnt have a EGR system.
for NO codes you will want to run a 88-91 Si (pm6 ECU) or 88-89 5speed Teg ecu (pg7) or if you can find out a JDM ZC ecu (pm7)
Old Jul 12, 2004 | 10:23 AM
crxzcracer's Avatar
Default Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">ok..
for NO codes you will want to run a 88-91 Si (pm6 ECU) or 88-89 5speed Teg ecu (pg7) or if you can find out a JDM ZC ecu (pm7)</TD></TR></TABLE>
yhea thanks man i was out side and swaped the ecu and then it hit me that the hf had the egr
and then auto teg ecu that you said early made sents to me
catamanchuk
Apr 12, 2013 07:18 PM
zc_crx
Feb 15, 2006 05:42 PM
drewboy
May 16, 2005 05:24 AM
