MPFI ECU into DPFI car?
Old Jul 10, 2004 | 10:46 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default MPFI ECU into DPFI car?
Could I plug in a PM6,7,or 8 inplace of a PM5? Would the engine run? How "Stock" would this be? My dad had a 89 civic LX sedan and it had a PW0 ECU in it. Could I run this ECU? I would like to get the ECU done and ready for my eventual MPFI coversation. I can proably change pins in the plugs but dont have the resorces to add sensors or any major wiring like that. I've done some looking around and can find squat an DPFI Roms and the like.
BTW it's a 91 Civic LX Sedan
Old Jul 11, 2004 | 12:11 AM
tehferret's Avatar
Default Re: MPFI ECU into DPFI car? (JC18)
You can and cant run the mpfi ecu on a dpfi car. What will happen is it will send too much fuel through the two injectors becuase it is looking for 4. Anway it will run but it will run like crap i would not do it. Just hold off untill you have everything for you MPFI swap.
Old Jul 11, 2004 | 12:24 PM
DieMaster's Avatar
Default Re: MPFI ECU into DPFI car? (tehferret)
what if I hook up the two injectors to #1 and #3 then hook up resterors to #2 and #4 so i dont get a CEL.
Old Jul 11, 2004 | 03:14 PM
DieMaster's Avatar
bump
Old Jul 11, 2004 | 05:24 PM
DieMaster's Avatar
Bump
what MPFI ECU would recomend?
Old Jul 11, 2004 | 05:32 PM
MonkeyMagic's Avatar
no no no no
but i like the way your thinking... be patient and use it later on bigger and better things
Old Jul 12, 2004 | 07:26 AM
DieMaster's Avatar
Default Re: MPFI ECU into DPFI car? (MonkeyMagic)
any more ideas?
Old Jul 12, 2004 | 09:31 AM
4drEF's Avatar
Keyboard Humorist
Just do the whole MPFI at the same time. The wiring might seem like it's a big deal, but it's really not. I might take you an hour to do since it's your first.
Old Jul 13, 2004 | 12:00 PM
DieMaster's Avatar
Default Re: MPFI ECU into DPFI car? (4drEF)
Ok, lets be realistic, what would a MPFI cost? How much would the intake manafold, the MPFI injectors and other stuff needed cost? Does the dizzy allready have the TDC sensor in it or do i need to get a dizzy that has one?
kyle48_2007
20
Apr 29, 2013 04:31 PM
hammergunner
Aug 26, 2009 02:09 PM
hondaluver12
11
Apr 28, 2008 05:05 PM
Civmochris
Dec 30, 2003 09:41 AM
