Help, knoi yellows brake line bracket woes..
Old Jul 10, 2004 | 07:13 PM
tolnep's Avatar
Default Help, knoi yellows brake line bracket woes..
91 CRX HF. Just got koni yellwws and ground controls and the ground control top shock mountings. Followed the koni directions. Got one of the brake brackets off easily from the old OEM shock. When to place it on the new koni with the little pointer right across the pinch bolt indentation on the koni shock and I cant get it the last 1/4 to 1/2 inch up the shock.
SHEESE! I'm afraid of damaging the shock. How in the heck do you get these things up to the correct place.
BTW.. did a search. No info about this problem. I've read the directions, the bracket is allgined correctly, its not on upside down. It just doesnt want to go the last 1/2 inch or so. Is there some secret here?
Thanks for help.
Old Jul 11, 2004 | 12:13 AM
EL Vap133's Avatar
Default Re: Help, knoi yellows brake line bracket woes.. (tolnep)
Zip tie it.
Old Jul 11, 2004 | 08:25 AM
goforbroke's Avatar
MEAT PATTY
Default Re: Help, knoi yellows brake line bracket woes.. (EL Vap133)
Get some lub and start spraying down along the shock where the brake bracket would go. You can get the brake bracket with a hammer just be careful.
bboysake
Suspension & Brakes
May 6, 2010 01:35 PM
fast95se
Nov 2, 2006 06:38 AM
SwiftTypeR
Jan 29, 2006 01:04 PM
fireant
May 4, 2005 06:47 AM
CRXTSEE
Apr 10, 2003 07:19 AM
