blows air but no heat
Old Jul 10, 2004 | 06:22 PM
4DRmafia's Avatar
Default blows air but no heat
i did put a new thermostat and all the hoes are hot but it still dont blow heat why is that ?
Old Jul 10, 2004 | 06:29 PM
4DRmafia's Avatar
could the cold and hot valve that mounted on the firewall outside could be stuck with cirt or crap inside ? and is there a fuse for it too ?
Old Jul 10, 2004 | 06:45 PM
old_school_civic's Avatar
Default Re: (SkipMic2006)
try flushing your coolant, the heater core could be plugged up with a buch of garbage.
Old Jul 10, 2004 | 06:49 PM
4DRmafia's Avatar
i did clean my heater core out and it clean if this dont work at all doesnt this mean ineed a new heater core ? and this 1 never been replace
Old Jul 10, 2004 | 07:45 PM
DieMaster's Avatar
Needs to be About 20% Cooler
check to see if your cable is working. turn the **** to heat, the little arm on the valve, i think, should be in a strate line with the pluming. if not turn it manualy and see if you have heat now.
Old Jul 10, 2004 | 08:00 PM
4DRmafia's Avatar
yea i did a deep serach on heater system and i think i found my answer for tmw so i gonna check on the vavle thing tmw and can i adjust the cable where the valve will open all the way?
Old Jul 11, 2004 | 01:20 PM
4DRmafia's Avatar
the plm sovled thanks guys
Old Jul 11, 2004 | 01:42 PM
DieMaster's Avatar
Was i right? Was it the cable?
Old Jul 11, 2004 | 01:52 PM
NFM_Dm's Avatar
Default Re: (JC18)
mine does the same **** ant figure out why.
Old Jul 11, 2004 | 02:07 PM
4DRmafia's Avatar
heh yea it was the cable and the valve opened the wrong way lol
91prelude4me
Apr 6, 2010 03:46 PM
sarah007
Jan 1, 2008 08:40 AM
jdmomar
Oct 26, 2006 06:52 AM
BRAGAN
May 31, 2006 05:25 AM
wetzelman1
Jul 12, 2004 12:28 PM
