OEM JDM HID parts needed for no rubbing?
Old Jul 10, 2004 | 03:48 PM
Ill's Avatar
Ill
Default OEM JDM HID parts needed for no rubbing?
I have searched and searched, but cant find a definitive answer. I checked with Brian Wong, but his answers have been less than complete.
I was under the impression you needed a JDM ITR washer bottle, ABS bracket, and PS resivoir bracket, to put OEM HID's in an USDM ITR with an OEM JDM nose. This to prevent rubbing of the HID ballasts.
Does anyone know for sure so I can track down the parts? Or should I just mount the HID's and run it with the rubs? I'd rather not take it all apart until I have everything sitting here. The non-HID's work ok for now. TIA.
Old Jul 10, 2004 | 03:51 PM
DragII's Avatar
25 Year Member
Default Re: OEM JDM HID parts needed for no rubbing? (Ill)
I didn't buy any of that stuff. usdm is fine. use some elbow greese
Old Jul 10, 2004 | 03:55 PM
Ill's Avatar
Ill
Default Re: OEM JDM HID parts needed for no rubbing? (.D2)
LOL Elbow grease. THAT's what prevents the rubbing - lube!
Old Jul 10, 2004 | 03:59 PM
DragII's Avatar
25 Year Member
if you have a type R, the power steering does not rub, the washer bottle doesn't interfere, neither does the abs....only the a/c line needs bending.
Old Jul 10, 2004 | 04:07 PM
Ill's Avatar
Ill
Kewl, thanks! If I later wanted to run a Mugen intake (considering it), can I still squish it in between the AC lines, and also bend them to clear the HID ballast (98 USDM R with AC)?
Old Jul 10, 2004 | 04:08 PM
DragII's Avatar
25 Year Member
yeah its the ac lines on the driver side that cause the problem, it's easy to bend them to fit.....I have an AEM intake so I don't know specifically about the mugen peice though, I'd imagine clearance is fine.
jonesvirs
Oct 15, 2013 04:47 AM
danny98r
Northeast (Sales)
Jun 16, 2009 10:31 PM
migs
Aug 15, 2003 05:19 AM
SpoonSpecR
Jun 4, 2003 10:45 AM
